Sponsored by: CARiD
Washer Nozzle removal
Old May 9, 2024 | 08:50 PM
OddJack's Avatar
Default Washer Nozzle removal
So Passenger side not spraying far enough, only a solid stream for an inch or two.
I am gonna replace the nozzle with a new one. How do you take the old one out?
Amazon Amazon
98 Z28
Old May 9, 2024 | 09:45 PM
LilJayV10's Avatar
You have to remove the windshield wiper cowl.
Be very careful when you do. I took mine off last week, and somehow, the plastic cowl hit the very corner of the glass and was enough to crack it.
When I came out the next morning my windshield had a crack in it. Freakin unbelievable.
To get the nozzles out of the cowl, there are clips that you squeeze and it comes right now.
Old May 9, 2024 | 10:23 PM
OddJack's Avatar
Thanks, Cant I just pry off the nozzle out with the cowl in place? I cant squeeze the clips from outside but if they break it wouldnt matter, I just push in the new nozzle in?
Old May 10, 2024 | 09:01 AM
wssix99's Avatar
Save the manuals!
Everything is plastic, so you would risk damaging the cowl. Maybe you could drill into the old nozzle, destroy it and get some leverage that way, but you would also risk unintended damage that way.
Old May 10, 2024 | 10:28 AM
bleepster's Avatar
can you use a long pin or a paper clip to clean out the nozzle?
Old May 10, 2024 | 11:18 AM
OddJack's Avatar
I tried that already, it's now a fat but short stream.
I probably will go with the drill idea. I won't be removing the wipers.
Old May 11, 2024 | 10:06 AM
wssix99's Avatar
Save the manuals!
I would try a drill and screw extractor, then. Something that will grip and allow you to pull outward.
Old May 11, 2024 | 02:46 PM
sjsingle1's Avatar
i just did the nozzle replacement yesterday....someone had did the job previously.....they destroyed the cowl by trying to get it out from the top like you are !!!
lucky for me I have a spare cowl
the nozzles are cheaper on rock auto btw
