Sponsored by: CARiD
Oil pressure issue
Old Aug 19, 2024 | 12:33 PM
Irod24's Avatar
Default Oil pressure issue
Hey guys I’ve read a bunch of stuff from a lot of threads from here and I made a page to see if yall can pin point my issue I have a 2000 Chevy Silverado 4.8 with a stage 2 cam and 3200 stall and everything possible to make it preform well and to not break on me after my cam installation I had it for 2 days and on the second day I was coming home and was leaking oil for a block or 2 and ever since then I haven’t had any oil pressure I idle at 40 cold and up to temp is 20 I’ve replaced almost everything yall can think o ring pump gaskets everything under the book and I refuse to believe I spun a bearing cuz there is 0 noise from the engine if yall have any suggestions or questions pls let me know if yall can figure something out I’ll pay someone I js really need it fixed
Old Aug 19, 2024 | 12:43 PM
Treburkulosis's Avatar
Are you sure the gauge is working? Mine on my 01 did that and it was just the gauge acting up.
Old Aug 19, 2024 | 12:55 PM
Irod24's Avatar
I had bought a cluster yesterday from pi clusters so cluster is a check
Old Aug 20, 2024 | 08:07 AM
And the sending unit is working?
Old Aug 20, 2024 | 09:03 AM
wssix99's Avatar
Save the manuals!
You haven't done everything under the book until you have put a mechanical oil pressure gauge on the engine to see if the thing on your dash is telling you the truth, or not.
