02 LS1 charging idle problems
Here's what i need help with.
When the car is idling in park/neutral and the ac is on the charging system is doing what it's supposed to. When it is put into gear and idling it seems like it cannot keep up. The system drops to about 13v and the ac doesn't cool as well as it should or as well as it does in park/neutral. The blower speed seems allowed down as well. When driving down the road everything works as it should as the voltage is above 14.5.
Has a new alternator. Just seems like the computer isn't compensating for the load at idle. Did the same thing with the old alternator.
Also has a slight misfire at idle, but no codes. There are no codes at all. Has new plugs, wires, and coils. Can see the misfire on the tech 2 misfire graph.
Any thoughts or ideas. Thanks in advance.
Ben
Watching the tech 2 when idling in p/n it is commanding a 650rpm idle. The moment it is put in gear; it's being commanded to 550rpm at idle. That seems low. I cannot find info on what the idle speed are supposed to be. Does anyone have that info? Any thoughts on why it would be doing this low of an idle? Thanks in advance.
Ben
Ben
You can raise idle speed with tuning, but it really shouldn't need a higher idle speed if the cam is stock.
You can also upgrade to an alternator that makes more amperage at lower engine speeds, and/or swap to a smaller pulley (but then max rpm is limited, or alternator damage could result - not really a concern if your shift points are still stock though).
But if the engine seems to have a misfire at idle, I'd look into correcting this first. Even if there are no codes, your scanner should show cylinder specific misfire counts. So if it registers the misfires on a general graph, look for the cylinder specific data and see what (or which) cylinder(s) is/are responsible. If the cylinder specific counts don't show anything noteworthy for any specific cylinder, then look at the fuel trim data and see if the LTFTs are elevated on either (or both) banks. They shouldn't really be more then +/- 5% or so on a good running stock car (I'd call +/- 10% the upper limit). If the trims are at all elevated, then you might want to look at fuel pressure next. Could also be that an injector or two or three are a bit gummed up if the fuel system has been neglected (such as very old, untreated fuel left in the system) at any point in its life.
Thanks for the idle specs and it's doing what it's supposed to. You can raise idle speed with tuning, but it really shouldn't need a higher idle speed if the cam is stock.
I'm trying to get everything corrected before i do any tuning. You can also upgrade to an alternator that makes more amperage at lower engine speeds, and/or swap to a smaller pulley (but then max rpm is limited, or alternator damage could result - not really a concern if your shift points are still stock though).
i put a new 165 amp alternator on the car last weekend. The problem carried over from the last alternator. Voltage from the alternator on p/n at idle is about 14v with the ac on or off. In gear it's hovering about 12.8v and with the ac on it's down to 12v. But if the engine seems to have a misfire at idle, I'd look into correcting this first. Even if there are no codes, your scanner should show cylinder specific misfire counts. So if it registers the misfires on a general graph, look for the cylinder specific data and see what (or which) cylinder(s) is/are responsible. If the cylinder specific counts don't show anything noteworthy for any specific cylinder, then look at the fuel trim data and see if the LTFTs are elevated on either (or both) banks. They shouldn't really be more then +/- 5% or so on a good running stock car (I'd call +/- 10% the upper limit). If the trims are at all elevated, then you might want to look at fuel pressure next. Could also be that an injector or two or three are a bit gummed up if the fuel system has been neglected (such as very old, untreated fuel left in the system) at any point in its life.
Long term in p/n ac on is:
-2 for bank 1
-1 for bank 2
ac on is:
-3 bank 1
-2 bank 2
in gear ac off:
Both banks -2
in gear ac on:
-2 bank 1
-2 bank 2
I'm gonna get the battery tested next. If you guys see anything with this numbers; let me know. I will really appreciate it.
Ben
once everything is fully hot after a drive. Idling in gear with the ac on and blower speed max the voltage is down to 11.5.
the misfires seem to be gone. Even on the tech 2 graph.
