Sponsored by: CARiD
Fuseable link location on Gen IV LS?
Old Aug 8, 2025 | 10:20 AM
alamantia's Avatar
Default Fuseable link location on Gen IV LS?
I went to start my start my 2002 Z28 today after sitting for a few weeks on a battery tender. With the key in the ACC position all the lights were on in the cluster as normal. As I turned the key everything went dead. Battery is good, now nothing comes on. Not even the dome light or radio or even headlights. I suspect a blown fuseable link but I am not sure where it is or if there are more than one I should be looking for. Any ideas?
Old Aug 8, 2025 | 10:55 AM
Finkledbody's Avatar
Probably a bad ground connection due to corrosion at the battery terminal. Super common with these side posts batteries.
Old Aug 8, 2025 | 11:46 AM
alamantia's Avatar
That was the first thing I checked and there was zero corrosion. Thanks tho
Old Aug 8, 2025 | 01:10 PM
Full Power's Avatar
Not even headlights ?
Your battery is probably GONE. Try a high rate load tester... Replace if it won't take a good charge AND pass a LOAD test.
If it's NOT battery:
1) Check the negative battery cable --- likely/ probably corroded inside.
2) Replace or fabricate a NEW positive cable that goes from battery to starter solenoid/ and splits off to junction block near alternator. It's probably 23 years due.
Old Aug 9, 2025 | 06:04 PM
alamantia's Avatar
I found the links. I was wrong, they were fine. Battery termanals were getting hot so I had to locate the short. I took a guess and dropped the starter and everything lit up as it should. I ordered a new delco starter. Thanks for the suggestions. Much apreciation.
Old Aug 9, 2025 | 07:25 PM
Robbi18's Avatar
Check the fusible link by the battery it’s likely blown. Clean the terminals and test. If still dead, ignition switch could be bad.
