Sponsored by: CARiD
2002 engine light blinking
Old Dec 19, 2025 | 07:07 AM
Daveone23's Avatar
Default 2002 engine light blinking
The light blinks once in a while if the car has not been driven in a while. It does not throw a code. If its missing wont it throw a code?
Old Dec 19, 2025 | 01:26 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
The only (correct) reason for the SES light to "blink/flash" would be a serious misfire. And this will be accompanied by misfire codes, including P0300 (random multiple misfires) and a P030x (x = 1-8, which would be the cylinder specific misfire code).
If there are no codes present but you're seeing a flashing SES light, there's either a wiring problem or a PCM hardware/tuning problem.
Old Dec 19, 2025 | 05:11 PM
Daveone23's Avatar
P0300 and p0332. Can i bypass knock 2 wire to knock 1. Dont want to change it out.
Old Dec 19, 2025 | 05:33 PM
RPM WS6's Avatar
So then you ARE seeing a P0300 code. You said this was not happening in post #1, so I assume the situation has changed?
In any event, you have a misfire.
Do you have access to a scanner that shows cylinder specific misfire data? That would be helpful, but not entirely necessary to begin diagnostics. You can also look at fuel trims (if you have a comprehensive scanner) for anything out of sorts on one bank or the other. Additionally, there should be some freeze frame data on that P0300 code to help you determine when (and under what conditions) the code was triggered; that also might help with the diagnostics. Otherwise, first step would be a basic check of plugs and wires (for fouled plugs and/or failing wires leading to weak spark/lost spark), as well as obvious/easy checks such as the air filter and MAF for debris/grime and/or obstructions, etc.
Old Dec 20, 2025 | 07:23 AM
Daveone23's Avatar
It only does it when the car has been sitting. Run it for an hour and it goes away and runs well.
Old Dec 20, 2025 | 11:52 AM
Daveone23's Avatar
Is this the connector for the knock sensors, green and blue wires.
Old Dec 20, 2025 | 01:18 PM
RPM WS6's Avatar
Knock sensor is not the reason for your misfire, that's a separate issue. Knock sensors are located underneath the intake manifold and would require manifold removal to be replaced.
Address the P0300 as outlined above.
