Sponsored by: CARiD
Hunting idle, Resolves with restart?
Old Mar 1, 2026 | 10:41 PM
LS1Silverado05's Avatar
Default Hunting idle, Resolves with restart?
Ok all, I picked up a 98 Firebird tonight, dead stock other than cat-back, and it seems that on an initial start it sometimes will not immediately find an idle and will hunt up and down consistently. If I shut it off and restart it immediately, it’s smooth as silk.
Does that give anybody any idea what I should be looking for?
Appreciate it!
Old Mar 2, 2026 | 03:21 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Lots of potential causes and hard to say with such limited data.
- Could be an IAC motor that's failing.
- Could be a weak battery condition that's causing the need for a partial idle relearn after being discharged by an engine start (this is a rare one, but it has happened to mine - and would clear up with a key cycle just like yours).
- Could be an intermittent vacuum leak that is cleared by a restart (such as the EVAP purge solenoid).
- Could be an issue with the EGR valve (this was actually a recall on the '98s).
Have you looked at fuel trims (scanner), fuel pressure (gauge hooked up to the rail), IAC counts (scanner), and/or performed any other diagnostics yet? Any codes pending, stored, or active?
Old Mar 2, 2026 | 08:09 AM
I haven’t made it so far to scan or anything. There’s no dash lights but unsure on stored codes
My immediate thought was the IAC but wasn’t sure it made sense it would clear up on an immediate restart if the hard part itself was bad.
I’ll keep digging.
Old Mar 2, 2026 | 08:40 AM
wannafbody's Avatar
If it's not a GM or Delco IAC valve that could be the issue. I bought one from Autozone and it wouldn't idle right.
Old Mar 6, 2026 | 02:25 PM
Ape Man's Avatar
The hunting fixed with IGN cycle lead me to believe its an IAC. Mine was doing similar thing, but WOULDNT idle without throttle, key cycle fixed. Was a purge valve sticking open
Old Mar 11, 2026 | 05:06 PM
Where is this purge valve located?
Old Mar 11, 2026 | 06:47 PM
RPM WS6's Avatar
In the engine bay, on the driver's side of the engine, just behind the throttle body and next to/on top of the intake. Small black piece that connects to the intake via a hard gray plastic line (be careful with this line, they break easy and I think they are discontinued). It's a quick-disconnect style.
Old Mar 11, 2026 | 08:27 PM
Oh I know exactly the one... as soon as you said it was prime to break lol
