jack stand / floor jack placement
front: some guys use one jack under the main K-member (brace under oil pan). Some people jack up on the flat subframe areas located behind the front wheels, just inside of where the fender bolts to the body structure. There are some flat places that look like frame, with a couple holes drilled in it. About 10 inches from the side of the car.
As long as you aren't jacking up on anything that is attached to a outer body panel, or directly to the floor pan, you should be okay.
Take your time and watch out for the jack stands as they could begin to tilt when you are jacking up the opposite side of the car. BE VERY CAREFUL.
Oh well. I'll just change the oil this weekend instead.
