Sponsored by: CARiD
changing spark plugs
Old Aug 25, 2004 | 10:14 AM
starente's Avatar
Default Help! Question about changing spark plugs
Hi
Does anyone know how to change the 2nd cylinder spark plug on a 1997 Camaro (eight cylinder). Is there a trick to this or do I need to remove anything to gain access?
I've managed to get to the other 7 but can't figure out how to change this remaining one.
Thanks
Chris
Old Nov 23, 2004 | 10:10 PM
kenp's Avatar
Originally Posted by starente
Hi
Thanks
Chris
Are you talking about the plug on the passenger side at the rear of the engine or the front of the engine?
Old Nov 30, 2004 | 12:06 AM
Z-286speed's Avatar
If you have headers, go from the bottom with the car jacked up.
Old Nov 30, 2004 | 11:02 PM
97cobra's Avatar
buy a cobra... its real easy! ha ha. those things are a bitch to change, my buddy has had a lt1 z and a now a ls1 ss.
Old Dec 3, 2004 | 01:37 PM
ChevE's Avatar
This may help...
On my 98 Z28 , I ended up getting two 1/2" swivels, this allowed for a much easier removal of that spark plug. If needed get a breaker bar or ratched with a longer handle. I am assuiming you can disconnect the head risers (proper term?) as long as your careful of the mettalic gasket when you do so.
Best of luck
Old Dec 6, 2004 | 12:26 PM
BLACKDEATH's Avatar
you get it from under the car
