Sponsored by: CARiD
LT1 starting problem
Old Aug 25, 2004 | 11:37 PM
OmniRex's Avatar
Default LT1problem
I was passing a car today, downshifted to third.
then the car freaking dies...well sputters then dies.
It will turn over and then will suptter and die, I have spark, the fuel pump works and I had gas, what could it be?
Old Aug 26, 2004 | 12:36 PM
Z284thgen's Avatar
are you checking the fuel pressure or just listening for it when you turn the key on . i would suggest putting a gauge on it and see what it shows.
also check the fuel filter.
Old Aug 26, 2004 | 12:37 PM
SeeYaSucker's Avatar
Optispark maybe?
Old Aug 26, 2004 | 03:29 PM
5432LT1's Avatar
Originally Posted by SLVRZLS1
Optispark maybe?
DUH DUH DUUUUHHHH!
**Young woman screams in background**
Old Aug 26, 2004 | 04:46 PM
OmniRex's Avatar
I thought optisparks gave some sort of warning before they went out?
Mine car just died out of the blue and its acting like its timing is off, could the icm be fried?
It better not be the opti...
Old Aug 26, 2004 | 05:56 PM
S8ER95Z's Avatar
yeah..my opti spark gave me advanced warning.
I backed out to goto work..it was running a lil choppy. Idle Smoothed out..sounded like it was running perfect! (thats when I realized something wasnt right). I made it forward about 2 feet back into my driveway and ended up pushing it the rest of the way. Just like that.
Old Sep 4, 2004 | 06:12 PM
OmniRex's Avatar
I got the code its throwing, its code P0100, Maf insufficent, but that wouldn't keep the car from running would It, If I disconnect it. It should run in speed ddensity mode...
wtf?!
P.S. thats the only code its throwing..
Old Sep 5, 2004 | 04:05 AM
S8ER95Z's Avatar
I dont know about this whole disconnected maf thing. If i inplug mine the car wont start,refuses to run. Sounds like you need to swap one out with someone and test it. Im not sure what that code means exactly, but I would try to swap a different maf in there.
Old Sep 5, 2004 | 09:55 AM
TwoFast4Lv's Avatar
Yes if you lost the MAF by disconecting it she will go into MAP mode and run
While you are at it see if the bellows pulled off the TB.
Back when I had a blower on the car I would blow a hose about once a week. I was running 14Psi. Just like you said yours did the car would die and I would have to coast to the side of the road. It would not restart untill found the hose that blew off and fix it.
Good luck!
Old Sep 5, 2004 | 07:02 PM
OmniRex's Avatar
all the hoses are in the right places... the opti throws a code when its fucked doesn't it? maybe I broke my timing chain?
Old Sep 6, 2004 | 08:29 AM
a5150ward's Avatar
My opti gave very little warning. It misfired/backfired every once in a while, but then one day I floored it and it sounded as if my driveshaft exploded. It continued to crackle up until I took the key out. Then it would not restart. I had it towed to the shop (Don Lee in Rancho Cucamonga). I only threw a TPS and Fan code (no opti-anything). After changing the TPS and ICM with no help we figured it had to be the Opti. When they got it off it rattled like a toy. We took it apart and wow. The screws had backed completely out and come off the rotating arm. The plastic dowel pin on the arm had also broken off.
You can see that it was taking itself apart from the inside. We did not unscrew the rotating arm; it was off hanging on its own. Out of control.
Old Sep 7, 2004 | 11:35 AM
Z284thgen's Avatar
my rotor came off mine while i was at ed wrights dyno tunning my car. and it happened at 5500 imangine what that sounded like. also let me add the opti was less then 1 months old the new one i took apart and locktighted the screws in and then installed
