Sponsored by: CARiD
Still Won't start
Old Oct 12, 2004 | 06:28 PM
impact1968's Avatar
Default starting problem
Have you checked the theft relay, jumper the heavy yellow and purple wires together, when you turn ignition switch to start, engine should crank then start and run, if the engine shuts off in about 3 seconds then the problem is a bad theft module, if it starts and stays running bad relay, doubt its the relay or ignition switch though as those are pretty sturdy pieces.
Old Oct 13, 2004 | 02:10 PM
ButtaballZ28's Avatar
I had the same exact problem.....it was my ignition switch....mine went while i was going 60 on the highway and my car just shut off. When i was trying to start it nothing would come on that usually comes on like the fuel pump or the lights on the dash and the windows wouldn't roll up and my radio didn't work but it still told the time but the alarm still worked and my power locks worked and all my lights worked. I had mine replaced at my buddies shop because i'm not too good with electrical stuff and it looked like you had to take apart the entire column. Some of the symptoms i had while i think it was on the way out were that my volts were really low and sometimes i went to start the car and it would just die. I checked the alternator and the starter and the battery and all were fine. Ever since i replaced that switch all has been fine.
Old Oct 13, 2004 | 10:23 PM
Slow TA's Avatar
any prices on how much the ignition switch will cost?
Old Oct 16, 2004 | 01:57 PM
Slow TA's Avatar
ok its not the ignition switch either. When I turn the key to the on position everything comes on fuel pump lights radio it just won't start. I've replaced everything so now what?
Old Oct 16, 2004 | 10:22 PM
Camaroz's Avatar
have you checked the solenoid...?
Old Oct 17, 2004 | 01:27 PM
Slow TA's Avatar
replaced it. Its going to the pontiac house tuesday maybe they can fix it. for a price.
Old Oct 17, 2004 | 02:38 PM
Camaroz's Avatar
i bet its something ovbious that none of us thought of too
Old Oct 17, 2004 | 11:19 PM
TonyJ's Avatar
It's the ignition switch... really...
Old Oct 31, 2004 | 10:13 PM
TonyJ's Avatar
So what was it?
Old Nov 1, 2004 | 10:08 AM
Camaroz's Avatar
Originally Posted by TonyJ
So what was it?
I would like to know also.
Old Nov 1, 2004 | 01:31 PM
ls1fbod's Avatar
Originally Posted by Slow TA
replaced the starter and solenoid checked the crank fuse, checked lock and key switch. the battery and connections are good also. and its not vats.
when I try to start the car nothing happens. all my lights work and radio and everything it just won't start. it won't click or anything. I need help and I don't wanna take it to chevy.
You need to clean all the acid residue off the battery and thewires...The corrosion could prevent any clicking and turning over...Also replace the + and - cables....
Good Luck
