Sponsored by: CARiD
LT1 Air Pump
Old Oct 15, 2004 | 08:54 AM
95camaroz28's Avatar
Default Air Pump
I keep blowing out my air pump fuse and im not why if i remeber right wasnt there a recall on some thing with the air pump??
Old Oct 15, 2004 | 11:44 AM
curlyws6's Avatar
Yes, there was a TSB on this problem. Drop me an email and I will see if I can run down the TSB from the dealer which I scanned into a Word document. I have officially ended all my AIR problems with my long tube install .
Old Oct 15, 2004 | 12:29 PM
Tsb???
Old Oct 16, 2004 | 09:12 AM
O ok give me your email and ill drop you one. thanks
Old Oct 16, 2004 | 10:46 AM
TwoFast4Lv's Avatar
There was a free update from gm. Was new air pump and wiring/
IF I remember right you can just un-plug the air pump it self and it may not send a code.
It has been a LONG time. Mine was done under factory warranty years ago. I still have it all some where...sitting in a box
Old Oct 16, 2004 | 01:41 PM
Cerwin Vega Fan's Avatar
I tried unplugging mine and the SES light comes on.
Old Oct 17, 2004 | 01:20 AM
TwoFast4Lv's Avatar
Like I said it has been a while. you can disconnect some thing and it will disable it but not set a code. Might be a good I dea to dig through the LT1 Edit achives
