Sponsored by: CARiD
Security light problem
Old Nov 26, 2004 | 11:39 AM
joshua32's Avatar
Question Security light problem
I have a 95 t/a and for the past couple of days my security light has been coming on for no apparent reason....a couple of times i haven't been able to start it because of it and other times it comes on when i start the car and stays on while i am driving it. I am sure there is no short in the wire unless i just can't see it....does anyone no of anything i can do?
thanks joshua
Old Nov 26, 2004 | 11:53 AM
flame's Avatar
likely its the key cylinder sensor that picks up on the chip in the key
mine does it intermittently all I do is wiggle the ignition key cylinder around
Old Nov 27, 2004 | 03:58 PM
Poik's Avatar
Yeah, the connections in my key cylinder would not work when they key was turned to the "ON" position. Either replace the key cylinder ($$$) or splice a resistor into the VATS line it connects to. You do not want to be somewhere when you can't start your car! Believe me, I was 75 miles away from my house when this happened to me!
Old Nov 28, 2004 | 11:34 AM
joshua32's Avatar
thanks guys i appreciated the feedback
joshua
Old Nov 29, 2004 | 07:29 PM
LT1Factor's Avatar
Mine did that. Check your keys like they said above. Mine was different. It was my VAS sensor.
Old Dec 3, 2004 | 01:38 AM
01WS6/tamu's Avatar
Get a new lock cylinder and coded keys and you will be ok.
