Sponsored by: CARiD
97 overheating
Old Nov 28, 2004 | 01:57 AM
Pwebbz28's Avatar
Default 97 overheating
Cousin had an over heating problem other night. For some reason the fans are not coming on. Put new sensor in water pump, all relays are good. Sensor is getting voltage from plug. Fans DO work if i use a jumper wire in fuse box. is it possible for it to be the computer itself?
Old Nov 28, 2004 | 06:04 AM
Nite_Hawk's Avatar
i have the same problem. I replaced all parts in the cooling sys except the radiatior. I got my fans to come on, but, not until the temp really up there. I bought a slp fan override switch, since i'm in the desert. helps but need to have it looked at.
Old Nov 28, 2004 | 07:50 AM
Snow Dog's Avatar
check the air pump fuse make sure its good.
Old Nov 28, 2004 | 04:41 PM
Nite_Hawk's Avatar
mine is all good.
