View Poll Results: Do you use Mobil 1
Mobil 1 all the way
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
121
90.98%
Tried it and didn't like it
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
10
7.52%
Never have tried it
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
2
1.50%
Voters: 133. You may not vote on this poll
Just wanted to see what your thoughts are on Mobil 1 oil
German Castrol Syntec 0w30 is much better. But if you can't find it, then Mobil 1 0w40 or 5w40 are good alternatives. Mobil 1 5w30 and 10w30 show higher engine wear in hard driven LS1s since they are very thin 30wt oils.
Why do you all use oils that are so thin ?? Over here in the UK, there is only a small selection of cars that I would ever consider using an oil like a 0/30. I would never use it in a performance engine. What are the benefits ?
I know from experience, if you use it in a Subaru, expect very early big end failure, and there are quite a few other engines in the UK that dont like it. Use it, and some burn oil like its going out of fashion..
There's also mention here about oil. Using a thicker oil, increased oil pressure, similar oil temps, and no loss of power.
Surely thats good....
http://popularhotrodding.com/enginem...ck/0503em_ls6/
[/url]
[/url]
In my observations, the LS1 engine does show it's best engine wear when running a thick 30wt to mid 40wt oil. So a lot of the 0w40 and 5w40 oils out there would work very well. I would not recommend anything thicker such as 5w50, 15w50, etc, as it's not really necessary unless you road race it a lot and see constant 300F oil temps.
I just put the castol 0w-30w made in germany! The lifter noise is allmost gone after 80 miles driving tonight! oil pressure at idle was 40, it went to50 and I drove tonight it was 60 on the highway I change it 7 hours ago! Great stuff! I tried mobil 1, redline,royal p, etc.
Don't use Mobil 1 cause their synthetic oils are very thin.
I use Castrol Syntec 0W30 made in germany. Its actually made in Austria, I spoke to a Castrol engineer at a NHRA event and had bit of a Q&A
You find German Castrol only at Auto Zone.
Around April or when the track opens I switch to Red Line Oil 5w30 for the racing season then in Fall switch back to GC.
Maybe this summer I will try Royal Purple Racing-41
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
The Australian guys seem to mention this German stuff. Either way, a 0-weight oil will be very thin. I'l still be going for a 15/50 or a 10/60.
I'd never use any with a zero rating.
Just to see what others think.
http://www.ls1.com.au/forum/showthread.php?t=33333
http://www.ls1.com.au/forum/showthread.php?t=33447
#32
My oil analysis results from my Corvette prove this oil works extremely well in the LS1.
With 8000km on my oil (5000 miles) I got the following wear results:
Iron 8
Lead 1
Aluminum 3
Copper 2
Chromium 0
Tin 0
Silver 0
Titanium 0
Nickel 0
Vanadium 0
The guy who interprets my reports for me has told me this is by far the best LS1 oil analysis report he has ever seen. And he sees TONS of them!
#33
Kleeborp the Moderator™
Maybe this summer I will try Royal Purple Racing-41![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#36
I thought that Castrol Syntec was not synthetic but was dinosaur oil with a marketing name added to make it seem like it is synthetic. I don't much go for companies that have deceptive trade practices.
I only use full synthetic. No dino oil for me.
Mostly Mobil 1 10/40 in the street cars, Red Line 30 wt sythetic in the race car (no detergent or additives so no go for street cars) I got a case of RedLine 10/40 5 qt containers, but haven't used any yet. I need to check and see if it can be used in street catrs.
Perry
Perry
#38
11 & 7 Second Clubs
Originally Posted by 1 BLOWN V8
Just wanted to see what everyone thoughts where on Mobil 1 oil. I just did my oil change and added Mobil one and it seems like the lifters are making more noise now. It may be me. So what are your thoughts?
#40
LSX Mechanic
Amsoil is the best IMO.
I run Valvoline in this car.
If you plan on tearing down and rebuilding something bigger/better sooner or later, wasting money on expensive oils isn't necessary. I used 89 cent Pepboys 10w30 oil in my Blown LT1 car. After two years of insane amounts of abuse, the tear down revealed nothing out of the ordinary. Bearings looked good, etc...Used the same oil in two previous F-bodies with zero issues.
That being said, if you're just going to keep the car stock and try to prolong the life of the short block for as long as possible, spending the extra 2-3 bucks per quart might be necessary. but if you plan on going into the bottom end at some point, just run a decent $1.50/qt oil and be done with it.
