Sponsored by: CARiD
Air Bags
Old Jan 20, 2005 | 07:47 AM
gh94z28's Avatar
Question Air Bags
I had a 94 Z that was involved in an accident and the air bags deployed i since then bought a 96 Z shell with undeployed air bags and moved all of the equipment (motor, trans and wiring harness) into the 96. I am reusing my old air bag sensors but my air bag light stays on all of the time. Will the 94 air bag sensors work with 96 air bags? I have been talking to fbodysalvage (Thanks again for all of your help) because i thought that i need to get some undeployed sensors but i read that you don’t have to with our cars. Also which one do i have a derm or sdm? Any help with this would be greatly appreciated. Thanks
Old Jan 20, 2005 | 10:19 AM
GWTFI's Avatar
Your SDM (Supplemental Deployment Module) is either A) Bad or B) Triggered one of two times. Sometimes a Tech I can reset it, sometimes you have to find an unmolested one and swap it out. I believe that on the F-body its in the center console behind the shift boot. All SDM's are a stand alone year everytime too. IE: The SDM HAS to be from another 1994, a 1993 or a 1995 won't work.
Old Jan 20, 2005 | 03:31 PM
Gangly's Avatar
you should see numerous yellow asteners be under the middle console behind the shifter like mentioned above.
Old Jan 20, 2005 | 04:16 PM
gh94z28's Avatar
What does the sdm look like on a 94 Z? Thanks
Old Jan 20, 2005 | 05:46 PM
GWTFI's Avatar
Its a little silver box, about 2 inches tall, and maybe 3 x 4 inches wide and long. It'll have a big assed yellow connector coming out of it.
Old Jan 20, 2005 | 06:15 PM
gh94z28's Avatar
So is there a sensor and the sdm under the console? Soirry for all of the questions
Old Jan 21, 2005 | 07:53 AM
01WS6/tamu's Avatar
Chances are good that it has a deployment sensor problem. The best thing is to find someone with a scanner and see what dtc is stored. Then you will know exactly what direction to go in.
Old Jan 21, 2005 | 09:05 AM
gh94z28's Avatar
Thanks for everyones help
