Sponsored by: CARiD
electrical issue on my LT1
Old Jan 20, 2005 | 12:26 PM
kcshaner's Avatar
Default Help with electrical issue on my LT1 Please!
My 95 Z28 is having some serious electical issues issues that I need help with. The blinkers barely work, and when they do, the usually just turn on with dim light and don't blink, also a few times my car was not starting so I had to keep jumping it so I purchased a new alternator.....It worked for about a day then died again (had to jump it). So two days ago I install a new battery....the blinkers still do not work, it died yesterday and my charge is in the red at all times. What can I check that could be causing my problem? Any ideas?
Any help is appreciated
Old Jan 20, 2005 | 01:42 PM
TA TED's Avatar
STF Veteran
You have a partial short on a 12v wire or circuit that is putting a small load on your battery. You need to hook up an ammeter inline with the negative battery cable and then pull fuses one by one to determine which circuit the short is on. Once you find the circuit, you'll need to isolate where the short is.
Old Jan 20, 2005 | 01:46 PM
kcshaner's Avatar
Damn....Thanks
