Sponsored by: CARiD
too much coolant
Old Feb 1, 2005 | 09:17 PM
FormulaFire's Avatar
Default too much coolant
CAn adding too much coolant cause problems??
Old Feb 8, 2005 | 04:43 PM
WILWAXU's Avatar
There can be issues if you have air in the system..
Old Feb 8, 2005 | 04:49 PM
Z28_Ninja's Avatar
i am not positive but i would figure if you put put too much in it would just blow it all out of the overflow when it gets warm. Air is deffinetly bad, can cause you to overheat.
Old Feb 8, 2005 | 05:31 PM
well, my low coolant light was on, so I kept adding coolant to make it go off, and it still hasn't gone off, and it is slap full. What could be the problem?
Old Feb 8, 2005 | 05:34 PM
WhiteRhino's Avatar
Your censor could of went out.I think a few people have had a problem with it.Its on the radiator on the pass. side.
Old Feb 8, 2005 | 09:04 PM
Z28_Ninja's Avatar
dont even bother with the sensor, my has been going on and off for a few months now. just make sure the radiator is full and you should be all set.
