Sponsored by: CARiD
odd noise while cruising
Old Feb 14, 2005 | 07:31 PM
JimMueller's Avatar
Default odd noise while cruising
It seems I can hear a repeating squeaking noise emanating from the passenger side while cruising at low speeds. Sorta like the repeating squeaking you hear from noisy pads. But now I'm also noticing a scraping noise which appears to be on the passenger side as well. It's more of a light metallic scraping noise only when I make a right-hand turn.
I replaced all pads in mid-December. I've got PBR Metal Masters on the front, and HPS's on the rear.
Suggestions?
Old Feb 14, 2005 | 07:42 PM
Michael Ozorowsky's Avatar
Jim, I have the same light squeek every once in a while it is my alternator bearings. You may have the same thing. Something worth checking into. Pull your alternator and spin it see what happens.
Old Feb 14, 2005 | 07:44 PM
JimMueller's Avatar
The alternator is on the drivers side - would it really be loud enough to echo off barriers on the passenger side?
Old Feb 14, 2005 | 07:49 PM
Maybe??? Another thing to consider is the brake. For some reason my driver side right brake pad wore down more/faster than any of the other brake pads in the system.
Old Feb 14, 2005 | 08:01 PM
frankdatank01's Avatar
Nice way to check the alternator internals, use a mechanic's stethascope(spelling?) and set it on the alternator housing while engine running. Should be amplified and easy to identify.
