Sponsored by: CARiD
Oil Filter?
Old Feb 15, 2005 | 06:55 PM
RAMAIRNUT's Avatar
Default Oil Filter ?
I can't believe how small the stock oil filter is.Which brand and what part # do you use in order to get the taller size filter
Old Feb 15, 2005 | 07:31 PM
ulySSes's Avatar
I use Mobile 1's version # MI-206, not sure what the #'s are for the other brands.
Old Feb 15, 2005 | 07:45 PM
GM Muscle's Avatar
Off the top of my head I think the AC is a PF59 and the K&N is 2006 (think is actually HP2006). Just take note that some of the long filters hang below the front skid plate and oil pan. I tried the K&N on my last change and it has a 1" nut on the bottom, so that one probrably hangs lower than the M1 or AC.
Old Feb 15, 2005 | 08:58 PM
Matt D's Avatar
Retired Street Racer
Wix #51522
Old Feb 15, 2005 | 09:02 PM
01TAFlyer's Avatar
I use this one too, just keep in mind it will hold about a 1/4 quart more than the stock size filters. It is longer.
Old Feb 16, 2005 | 04:17 AM
ZR2877's Avatar
Alright it's not working or I don't know what I'm doing so I'll try this.
Rank Brand Part Number
1 AC Delco Ultraguard Gold UPF58*
2 Mobil 1 M1-206**
3 Mobil 1 (Stock Size) M1-107
4 AC Delco PF58***
5 AC Delco (Stock Filter) PF44
* Larger than filter PF44 and offers better filtering than the PF58 (will hold 1/4 quart more of oil than the PF44 filter)
** Larger than filter M1-107 (will hold 1/4 quart more of oil than the M1-107 filter)
*** Larger than filter PF44 (will hold 1/4 quart more of oil than the PF44 filter)
Old Feb 16, 2005 | 04:20 AM
ZR2877's Avatar
I don't know if you can still find the UPF58. I use the long Napa Gold filter but I'm changing back to the short filter because my car is lowered and the long filter is a little to close to the ground for me.
Old Feb 16, 2005 | 08:03 AM
Fulton 1's Avatar
I'm fairly certain that most if not all of the ACDelco Ultraguard Gold (UPF) line has been discontinued. I do have a case (6 filters) of brand new UPF58's I'm willing to part with. PM me if interested.
FWIW, my first choice would be K&N HP-2006, second would be Wix 51522/Napa Gold FIL1522.
Old Feb 16, 2005 | 09:08 AM
ulySSes's Avatar
I still use only 6 quarts with the longer filter.
Old Feb 16, 2005 | 09:26 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I've used the AC PF58 in the past, but use the PF59 (anti-drainback or whatever it's called) now. It's basically like the stock filter but longer. I use a full 6 qts of oil. Trying to find K&N & Mobil filters around here is near impossible.
I can't rank all the filters 'cause I haven't used them all.
Old Feb 16, 2005 | 10:10 AM
peteZ's Avatar
I've been using the PF59 with no problems - it's the one listed for the LSx truck motors and seems to be identical to the PF44 except for length.
Old Feb 16, 2005 | 12:46 PM
matts22's Avatar
I use K&N HP2006 and put 6 quarts of oil in. Works great so far. My car isn't lowered, so I can't comment on whether it would be something to worry about. It's definately not for me.
Old Feb 16, 2005 | 12:50 PM
black00TA's Avatar
i use the purolator PureONE. excellent filter, give it a try. basic size.
Old Feb 16, 2005 | 01:30 PM
smokin' joe 00 ss's Avatar
Wix 51522, Napa gold is a Wix filter too.
