Sponsored by: CARiD
Changing Plugs... advice?
Old Feb 16, 2005 | 01:30 PM
Spoolish's Avatar
Default Changing Plugs....advice?
I am getting ready to change spark plugs to get prepared for the juice. Any advice as to where to start, helpful hints or pointers, ect. Also, do the stock plug wires in the 02 SS still have those spring things? Those were a pain on my buddies 99 SS. Thanks
Old Feb 17, 2005 | 11:24 AM
mikes98z's Avatar
The drivers side isnt so bad....the passenger side are a PITA!! Especially the #8. You have to either go in from the bottom or remove the coil packs and go through the top. The spring things are the heat shields and if I were you, I would keep them. I kept mine and added a set of MSD's on my 98. Good luck! Mike
Old Feb 17, 2005 | 11:31 AM
99FormulaM6's Avatar
get headers. makes it alot easier. drivers side is cake...and ps just take off the coil packs. i think there was 5 screws holding it down. just make sure you plug the coil packs back in... (dont ask... )
