Sponsored by: CARiD
Window Motor ?
Old Mar 4, 2005 | 02:59 PM
HitmanLSX's Avatar
Default Window Motor ?
Ok when replacing the window motor what nuts/bolts do you need to put the regulator back in after drilling out the rivets? I'm getting one used. If I get one from autozone (siemens) does it come with the bolts necessary?
Old Mar 4, 2005 | 07:53 PM
HitmanLSX's Avatar
Anyone?
Old Mar 4, 2005 | 08:10 PM
ddelallata's Avatar
a replacement motor from autozone will come with the hardware.
You will use 3 screws and 3 locking type washers. here's a good write-up for you. http://www.metalreviewcentre.com/Window.htm
Old Mar 4, 2005 | 09:07 PM
VIP1's Avatar
Copy & Paste Moderator
You dont need to remove the regulator...just the motor. Like ddelallata said, the Siemans window motor from AutoZone comes with the necessary hardware. I also used the same writeup that ddelallata posted: http://www.metalreviewcentre.com/Window.htm
Old Mar 4, 2005 | 09:24 PM
HitmanLSX's Avatar
k I might be getting a window motor used from one of the guys here which is why I was wonderin.
