Sponsored by: CARiD
No fire... stumped.
Old Feb 26, 2005 | 05:07 PM
DietCoke's Avatar
Default No fire... stumped.
Has fuel, pressure is perfect.
Has spark.
Has air.
Will not fire.
Have replaced:
Coil/ICM good (assuming test ones were good. It does spark at the coil wire)
New opti.
Plugs/Wires brand new.
Will turn over just fine, no fire. I'm completely baffled at this point, and am open to ideas.
Old Feb 27, 2005 | 10:36 AM
94redz28's Avatar
My car is doing the exact same thing.
Old Feb 27, 2005 | 02:36 PM
GhostZ's Avatar
So it's firing at the coil but have you checked at the plug? Pull a wire or eight off one at a time and ensure that they are firing at the plug itself.
You're checking all the right things. Check your fuses....ignition, ICM, injectors, etc.
If all fuses are fine and you're firing at the plug, check injectors to see if they're clogged. Where are you checking fuel pressure....off of the pitot in the back of the rail?
If all of that is in working order, I'd say have a closer look at the ICM. You haven't swapped to OBD1 have you? Recently changed timing sets and removed the CPS?
Give those a try and let us know what's happening.
Old Feb 27, 2005 | 03:45 PM
DietCoke's Avatar
OBD1. I can understand an injector possibly being clogged, but even firing on 6 or 8, the car should run. Is and always has been an OBD1 car, there is no CPS .
Fuel pressure on the rail. 45 psi and steady.
Old Feb 27, 2005 | 05:42 PM
DietCoke's Avatar
Getting spark at the individual wires as well. All injectors have 12 volts on the hot wire.
Old Mar 2, 2005 | 11:12 AM
DietCoke's Avatar
(This is resolved. Opti dowel on 120 degrees off, go figure.)
Old Mar 4, 2005 | 12:11 PM
nemanracing's Avatar
same problems i've had except my car just died on the road any advice would be nice... have air, spark, and fuel, still no fire
John
Old Mar 4, 2005 | 01:51 PM
1BigBird3's Avatar
How can the opti dowel be off? Isnt' there only one way it could fit? Did you do a opti install and THEN try to start it? Or where you driving it and THEN it just stalled, and has never fired since?
Happy to hear you got it fixed.
Thanks.
Ruben F.
Old Mar 4, 2005 | 03:53 PM
DietCoke's Avatar
Thanks.
Ruben F.
You would THINK it would only go on one way, but it can actually go on three ways. Opti was bad, replaced opti, wouldnt fire because new opti was installed wrong.
But there was also a bent valve involved so it'll be healthy again in a week when thats done with.
Old Mar 5, 2005 | 03:05 AM
1BigBird3's Avatar
I see. Would you mind being more in detail on how it would "sound" when you would try to start it? Did it kick over and just "putt putt" for 1 second then die, or did it just keep cranking and until you let off?
Thanks, I am just trying to pinpoint this problem myself as I just replaced my opti, opti harness, ICM, plugs, coil, even swapped in a spare PCM I have to ensure everything is in working order. I still get nothing except, it cranks over (you could barely notice, it literally gives two "putt putts" and then dies silently as if it were never on. I have a ScanMaster installed and the LT1 just doesn't stay on long enough to register a DTC. Very frustrating.
The shop I took it to, ran diagnostics and says for some reason the spark is coming before the fuel.
I just want this problem fixed so I can install the Delteq system.
Ruben F.
O-ya, The OptiSpark that was replaced, only had 7k on it, yet when I removed it from the LT1, I shook it, and it sounded like a spray paint can. (The ones with the marble in it.) I can't wait to dissect this POS.
Old Mar 5, 2005 | 10:57 AM
DietCoke's Avatar
IT would not fire at all, maybe a single put every few seconds.
Old Mar 5, 2005 | 11:21 AM
TwoFast4Lv's Avatar
Guys add to this. I recently had a customer who installed a new cap and rotor. with in a week the cap completely shorted out. Was a PITA to chase. We had fuel and fire. Every time I have had a car not start or run baddly when it had fuel and fire the opti in one way or another was the culpret.
I have about a Dozen of the darned things laying around now. the nice part is I hace some that probably just need a cap and rotor.(missing at high RPMs) so when ever I come across this problem I just slap one of those on to check. THis is easy to do for testing once you get to the opti. Leave the water pump and belts off and try to fire. If it starts right up you found the problem. If you are unsure slap the old one back on. We have even gone as far as swapping parts from the bad one to the good one till we pin pointed the problem.
I have also seen both styles of Optisparks installed wrong
Good luck!
