Sponsored by: CARiD
strange noise?
Old Mar 16, 2005 | 02:02 PM
Lt14mla's Avatar
Default strange noise?
hey all
Im getting a strange noise coming from i think my drivers side front area. The noise happens when i engange the car into drive idling still and also in reverse. when in neutral the noise doesnt happen. it sounds like a heavy clicking noise. any ideas guys
Old Mar 16, 2005 | 02:16 PM
WhiteBlur's Avatar
Does the noise stop after a second or two? or does it just keep clicking? To start i'd get a buddy to help and just shift it in and out of reverse and drive and see if you cann't find where the noise is coming from.
Old Mar 16, 2005 | 11:09 PM
Gloveperson's Avatar
Where in central NJ are you if you need a friend to help you out?
Old Mar 17, 2005 | 04:32 PM
Lt14mla's Avatar
hey todd im in hillsbrough i talked to you on njfboa i think. my sn for aim is bedofrazorz666. hit up sometime and we can talk. wouldnt mind chillen with another f-bod brotha
Old Mar 17, 2005 | 05:23 PM
Right now I am not in boro, but I should be there within a week or two and I can help out then.
Do you know the Petrocks, btw? Trevor is very good at fixing these cars; he has been helping me out for almost two years now so he could also help.
You have a silver formula right?
Old Mar 17, 2005 | 05:26 PM
Shawn MacAnanny's Avatar
Sounds like maybe your tourque converter bolts are coming loose. Check them out, i have heard of it happening a few times. You will need to remove the bellhousing dust cover and turn the engine with a breaker bar. It should only take 20 minutes to check though.
Lt14mla's Avatar
yea i have the silver formula. I know trevor through some friends ive been to his place a few times. Just give me a shout when u get in town bro.
Old Mar 18, 2005 | 01:13 AM
Huntr1117's Avatar
Could that be what my noise is? I had the car up on a lift the other day and I could hear a ticking noise that sounded like it was comming from the front of the tranny. Did yours make that kind of noise?
 Michael S. Palmer
Old Mar 18, 2005 | 09:01 AM
It could be. I had that problem with a 79 camaro of mine, a friends 3rd gen, and 2 friends 4th gens. It's pretty common. I would check that. It's not like it takes alot of time or anything especially if you have a lift. Just removed the dust cover and use a wrench to tighten down the 3 or 4 torque converter bolts. You can spin the engine with a 5/8 spark plug socket on the crank shaft.
