side mirrors
The ones with only the driver side having remote control, are the same for 93-02.
For both being remote control, they changed designs part-way through 1999. (So 1993-1998 and the first part of 1999 are the same; and the second part of 1999 and 2000-2002 are the same.)
This is regarding the main mirror unit, there are some of the small component parts that have the same part# all across 1993-2002.So although the body style changed in 1998, one type of mirror changed a bit later and the other type didn't change at all... so you're both right
The 93-98 part numbers for all-remote (RPO code DG7) are LH: 10276436 (driver), RH: 10279435. The 93-02 part numbers for half-remote (RPO code D35) are LH: 12528882, RH: 12528881.
