Sponsored by: CARiD
Plug difference
Old Apr 29, 2005 | 09:13 AM
xtinctbird's Avatar
Default Plug difference
I'm getting ready to get some new spark plugs, I'm going with the ngk's they come in regular for around $2 or iridium for $8. What the hell is the difference and is it worth the damn money.
Old Apr 29, 2005 | 09:22 AM
-PEPE-'s Avatar
If you do a search on lt1 plug choices you'll find it almost turns into an LT VS LS thread majority of the time. Everyone has a preference depending on their applications. For stock engines the platium plugs, iridium, yada yada yada are all fine. On the other hand if you run nitrous don't use the platinums because of the potential desoldering of the tips in the cyl head is what I've researched. With my AFR heads I preferred running old school Autolites 1 or 2 degrees hotter which ran great with race fuel mixes . try http://web.camaross.com/forums/ if you can't find anything here. Good luck especially on the passenger side, word of advice drop the starter makes it much easier.
Old Apr 29, 2005 | 09:31 AM
xtinctbird's Avatar
Thanks man I called napa and asked for the ngk tr55's the guy got pissy with me and said they changed the way they label them and then asked if I wanted regular plugs or I quote" those wierd fancy *** iridium something or other plugs". Brought up my initial question and spuured me to tell him what he could do with his plugs
