Sponsored by: CARiD
strange ignition switch problem
Old May 4, 2005 | 02:51 PM
Formula69's Avatar
Default strange ignition switch problem
ok well i went to start my car today, it turned over but when i let go of the key the car shut off... sounds like an ignition switch to me, but heres the weird part. i JUST replaced the switch like a month ago.. also when i put the key in the ACCY position, it does everything except cycle the fuel pump.. i have my fans and water pump wired to come on with the ACCY also, but only the water pump comes on, no fans.. could this be the switch? or maybe just one of the pigtails coming off of the switch? im confused
Old May 4, 2005 | 06:19 PM
Snow Dog's Avatar
id check the picktails first since thats easiest. i had brake light problems because of the connectors under the dash by the column. beyond that im not sure.
Old May 5, 2005 | 11:48 AM
blunto's Avatar
As far as letting go of the key and the engine cutting off, that sounds like it could be the igntion lock cylinder.
