Cooling Problem / Low Coolant
However, when the light comes on the car tends to run warmer. Normally driving down the road it will run 170*. When the light comes on driving it's fine, but when idling the temp will rise to 210* when the light is on. Granted, I know 210* isn't all that hot, just seems like a bit of a jump from normal.
I bought a new cap, one with a pressure release. When I parked the park I lifted the lever some to let the pressure release. After 5 secs or so the overflow bottle overflowed. Is this normal?
if you own an lt1, your guage work just fine....
if you own an ls1, then thank your uncle GM... they figured the average person would only worry if they saw the temp change from time to time (it is supposed to go up when you are idling, and down when the wind hits the radiator, and down when the fans kick on) so gm mad the guage to comfort you... it starts cold , then when you start the car it will slowly make its way to mid way... there it will stay... the only time it will move is if your car REALLY over heats... then it will slide into the red....
but until that happens you wont know...
now if i am not mistaken you have a 97?
if so then you have a lt1... and if it drops to 170 when you are driving then you have a 160* thermistat... and it goes to 210 when you are idling means you have a 160* TM but you have not had the fans changed to turn on and off within the 160* TM range... the fans are working like you have the stock 190* TM
i supose its possable your pcm does not like the big changes... dont know?
