Sponsored by: CARiD
ac problems
Old May 12, 2005 | 09:31 PM
slowride_3's Avatar
Default ac problems
can cross ac relay ac comes on.The relay is good.So what would the problem be
Old May 13, 2005 | 09:44 AM
HBHRacing's Avatar
many things. AC request, low freon, bad pressure switch. Step one is chekcing the pressure. I would invest in a set of manifold gauges.
Old May 13, 2005 | 10:12 AM
xsbc63x's Avatar
probably needs a charge or have a leak
Old May 13, 2005 | 03:46 PM
94strokedz's Avatar
If it comes on when the relay is crossed, then there is nothing wrong with the freon. Sounds like the computer is not putting the output to the relay to turn it on, or it is putting it out, but the signal isn't making it to the relay. When it comes on, if its not cold, then I'd investigate the freon/check for leaks.
Old May 13, 2005 | 04:57 PM
HBHRacing's Avatar
Thats not true. if you jump the relay it will come on even on an empty system. The relay is the last trigger in the system.
Old May 13, 2005 | 05:32 PM
xsbc63x's Avatar
if you have low freon it will not come on its a safety device
