Oil pressure problem
I recently started having a problem with my LT1. If I'm going down the road, I'm fine. The oil pressure needle is between the 0 and halfway mark. When I get to a stoplight, it falls right near the red, and sometimes even on the red. My check gauges light then comes on. I usually put it in neutral and give it a little gas, and it solves the problem.
I've checked my oil and I'm full. Other variables may be my valve guide seals that I need to change, since I produce some blue smoke time to time. My question is, do you think my gauge or sensor is just bad, or is something else wrong? Should I be running this car on the road?
-Thanks
