Sponsored by: CARiD
oil change comin on
Old May 22, 2005 | 05:27 PM
478TAM6's Avatar
Default oil change comin on
ok i just got new eldebrock lts on whenever i first start the car the oil change light comes on for about 1 minute and then it goes off and i cant tell if its the oil pressure or what.its also runnin rich as hell but im gettin a tune this week.need some help thanks.
Old May 22, 2005 | 05:57 PM
2001NBMZ28's Avatar
That's the GM Oil Life System. Did you reset it last time you changed your oil? If you're not due for a change you can reset it by turning the key to run (with the engine off), push the trip/oil reset button on the dash until it starts blinking then goes off. You can also turn the key to run and pump the gas pedal 3 or 4 times. If you haven't changed it in a while - it's time.
Old May 23, 2005 | 06:37 AM
kkkevvvinnn's Avatar
mine has been doing that to...if i change my oil and reset it will it come back on again in 3000 miles
Old May 23, 2005 | 07:25 AM
777's Avatar
777
I never see mine.
Old May 23, 2005 | 04:45 PM
8-Pack's Avatar
BTW the F-Body's system is set for regular oil, so if you use synthetic you can wait a little longer than when the lite comes on. Just figured I would share that.
