Sponsored by: CARiD
overheating
Old May 23, 2005 | 08:01 PM
joes99z's Avatar
Default overheating....
My buddies car is 94 trans am,
waterpump/thermostat/radator flushed/radator tanks replaced
He was driving car overheated, pulled over bubbling out of his resovor (can't spell) and, his fans weren't on, then it jumped down to like 160
Old May 23, 2005 | 08:13 PM
BizZzatch350's Avatar
Moderator
Y'all bleed the air out of the system?
Old May 23, 2005 | 08:18 PM
joes99z's Avatar
Pontiac dealership did it.
Old May 23, 2005 | 08:41 PM
Saad06's Avatar
just flush radiator... and use some good antifreeze.. make sure you do not mix the brown and the green... its a simple do-it ur self job.. if that doesnt work... post up again..
Old May 23, 2005 | 09:00 PM
FIREHAWK #07's Avatar
Originally Posted by Saad06
. make sure you do not mix the brown and the green....
you mean orange and green???? ....
Old May 23, 2005 | 09:04 PM
blk94z's Avatar
Check to see if the air deflector is still under the car. Had similar problems with mine when i bought it, after checking it had no air deflector under the car. Good luck with yours.
Old May 23, 2005 | 09:12 PM
I once flushed the coolant out and when I refilled it, the car still overheated; it wasnt the water pump or thermostat.... Turned out to be a $5 RADIATOR CAP......
Old May 23, 2005 | 10:33 PM
joes99z's Avatar
The air deflector is not under the car I believe my friend took it out for his cold air intake,
You think something like that will over heat the car? What about his fans not turning on, and the radator has been flushed twice all the way out.
Old May 23, 2005 | 11:05 PM
Saad06's Avatar
brown, orange.. same difference...
Old May 24, 2005 | 12:33 AM
Jordan57's Avatar
put the air deflector back. it has to be there otherwise no air is getting to the radiator....i mean seriously how is air gonna get forced in there? do it...now!!!!
Old May 24, 2005 | 09:20 AM
contraststriker's Avatar
I think the air deflector is the main reason it's overheating, but also: I have an electric water pump and 160* stat, but my car will slowly warm up (and I suppose eventually) overheat, if I have constant stop and go driving. I have yet to get LT1edit so I can, among other things, set the fans to turn on earlier. I think fans make a huge difference because once I get back up to speed the coolant goes right back down to 165.
Of course, now that I think about it maybe getting back up to speed just means the radiator is getting fed more air and thus chilling the coolant. Hmmm...
Old May 24, 2005 | 10:58 AM
joes99z's Avatar
Yes, but my friend said his car over heated and teh fans never turned on, any idea why?
Old May 24, 2005 | 11:36 AM
fans plugged in???
Old May 24, 2005 | 11:51 AM
BltonFirehawk's Avatar
tell him to turn on the AC and see if the fans click on at all....
Old May 24, 2005 | 11:54 AM
ls1_doc's Avatar
There is probably a fuse or relay for the fans check for either or both of those.
Old May 24, 2005 | 01:19 PM
Moderator
One way to do it is to pull the fuse for the air pump, that should trigger the ses lights and turn the fans on
Old May 24, 2005 | 05:27 PM
LT1-Z28's Avatar
Is that the cheapo "manual" fan switch?
Old May 24, 2005 | 05:33 PM
Wrastler's Avatar
Turn the heater on if your sitting at a redlight...i got stuck at one today for 5min, turned the heater on and it cooled roughly 50degrees according to the guage.
