Sponsored by: CARiD
gas pedal gets stuck
Old May 24, 2005 | 09:40 PM
JOEFASTZ28's Avatar
Question need help gas pedle gets stuck
need help my gas pedle got stuck six times today need to now what it is my last time it was redlining and i got 166.000miles on the engine it get stuck when im driving to
Old May 25, 2005 | 09:41 AM
HBHRacing's Avatar
step one. Remove the throttle cable andrun the throttle body blade by hand to see if it;s sticking at all. If it is give it a clean with some air intake cleaner and a rag. If not look for anywehre that the throttle cable is pinched, split, burnt or caught. if all else fails replace teh cable.
Old May 25, 2005 | 11:44 AM
curlyws6's Avatar
I would also check the TB and clean if needed with an 02 safe spray. I don't think it would cause the problem that you are having but might contribute .
Old May 25, 2005 | 04:20 PM
resurrectedz28's Avatar
Yeah, and make sure the carpet is not some how interfering with the pedal, happened to my sister once, and remember, all you gotta do is turn the car off, not stand on the brakes for two miles, like my sister did.
Old May 27, 2005 | 06:18 PM
DravenMyers's Avatar
thank for the help guy i ll try the tips
