Sponsored by: CARiD
Ohh it Burns; The Arcing!!!
Old Jun 9, 2005 | 02:52 PM
buffman's Avatar
Default Ohh it Burns; The Arcing!!!!!!!!!!
Well I got bored tonight, so I did the under the hood check for arcing test. I only got to closely look at a couple but I noticed the rear plug wire on the driver's side is arching, and I'm getting this strange blueish/purpleish glow coming from this less than 1 wk old MSD coil I purchased brand new. Before I go into extensive measures, w/ headers (I have a b-body so to be specific they're Try-ys) do I need those protective metal boots that go over the plug wires? That's what it's arching on on the rear.
Plugs have less than 2,000 miles on them, opti is original w/ a new cap and rotor 70,000 miles ago, and plug wires have 70,000mi on them too, (OEM)
Is there something wrong w/ my coil to be emmitting this glow around the coil frame??
Old Jun 9, 2005 | 03:21 PM
Rob 94Hawk 319's Avatar
There's a possibility that the ceramic part of the plug (isolator) is cracked.
Old Jun 9, 2005 | 07:46 PM
Snow Dog's Avatar
those are heat covers for the boots. you dont need them if youve got MSD wires or the headers dont come super close to the boots
Old Jun 9, 2005 | 10:54 PM
buffman's Avatar
hmm the plugs are brand spanking new. They only have 1500 miles on them. I guess I'll have to remove some of the arcing ones to see if they're cracked. I removed the heat boots tonight, and the one is arcing as much, but I still do see some even after applying dielectric grease inside the boots and installing the original coil. I wonder if the stock plug wires are about on their ends? I didn't notice any arcing on the pass side though..
Matt
