Sponsored by: CARiD
sqeeeak
Old Jun 17, 2005 | 01:08 AM
95camaroz28's Avatar
Default sqeeek
When i give my car WOT and it shifts into 2nd gear and get a sqeek from the belt maybe up front, i think its the belt not really sure, anyone else have this problem if so how to fix it?
Old Jun 17, 2005 | 02:47 AM
Saad06's Avatar
yeah, i had the same thing going on in my car when it was auto... do you have the "transmision perform" button?
Old Jun 17, 2005 | 03:55 AM
BlackScreaminMachine's Avatar
Internet Mechanic
All camaro have their Performance button "on", T/A's got the option of on or off.
But here is a quote from this website which is great for general FAQ stuff.
http://www.f-body.org/oldfaq/html/frames/ch4_fr.html
Q: What's that screeching noise from my automatic tranny on hard shifts?
A: If you've ruled out that it's the rear tires chirping, then it's most likely belt slippage. This is common on the Corvette LT1s and even some of the later L98 motors. On hard shifts (auto and manual trannys), the shift in the speed of the pulleys will throw the belt and hence the screech of it slipping. It's pretty harmless, although it can be annoying.
You can check with your dealer as there is a Technical Service Bulletin (#476109) which calls for replacement of the belt tensioner with an improved one (part #10238703). Some people have also replaced the A/C pulley, (part #2724717) and the belt (part #12550149).
Others believe the power steering pump pulley to be the culprit. The do-it- yourself solution is to raise the vehicle and support it with jackstands (or ramps). Either look to make sure you have an underhood sticker that shows the routing of the belt or make yourself a picture. Then get under the car and use the appropriate socket and "tighten" the center bolt on the belt tensioner pulley. As you "tighten", the bolt shouldn't move, but the tensioner will swing out, allowing you to pull the belt off with your other hand. Then take an old toothbrush and soak the head in alcohol. Then, for each pulley, spin it with one hand and hold the toothbrush against the surface of the pulley where the belt normally touches. Repeat this until you are pulling back a relatively clean toothbrush on each pulley. Since you can't turn the main crank pulley, just run the toothbrush around it until the pulley is clean. Note that you can accomplish this cleaning with the belt installed and the engine running if you know what you are doing, but this can be EXTREMELY DANGEROUS if you don't have practice and a steady hand because IT IS EXTREMELY EASY TO GET THE TOOTHBRUSH CAUGHT BETWEEN THE BELT AND A PULLEY WHICH COULD CAUSE SERIOUS INJURY. Try the first way to be on the safe side. After the pulleys are clean and the factory belt is off, you can roughen up the PS pump pulley by simply running sandpaper across the PS pump pulley from above. Watch your hands though, because those hoses up there can be HOT. Just scrape the sandpaper across the top of the pulley in a motion from the front to the back of the car. The trick is, you want to roughen the pulley, putting scratches in it in the opposite direction of the belt's travel. Scratch it just enough to dull the surface all the way around. Use a paper towel damp with alcohol to clean off the pulley all the way around where you sanded it to get the grit off. Finally, install a new belt (preferably, Gates K060637, 21mm x 1635mm) and make sure the routing is correct and the belt is centered on each pulley. Lower your car, start it up, and make sure the belt is staying on. Then you can hit the road and open it up, enjoying your quiet shifts (hopefully).
Old Jun 17, 2005 | 01:10 PM
If i wanted this button, where could i get it for my camaro?
So the only way to fix it is get a diffrent pulley tentioner?
Old Jun 17, 2005 | 01:17 PM
Internet Mechanic
As far as I read, Camaro always has it. I would figure you would need to see a wiring diagram for a trans am, and then get that exact perf. switch. Splice it in and mount the switch. But I would talk to someone who has done it. I myself have not heard of anyone doing such a thing.
Old Jun 17, 2005 | 01:21 PM
RAREws6's Avatar
the belt slip on my car is very noticeable in every hard shift for every gear exept 5th and 6th, my buddies think it's the tires churping, i'll let them think that
Old Jun 17, 2005 | 01:59 PM
I feel stupid with belt slip, everyone can notice it. ill try to figure out how to iminate it but i am very interested in this "button"
