Sponsored by: CARiD
F-body and LS1 Common Problems
Old Jun 20, 2005 | 11:29 AM
brotherhef's Avatar
Default F-body AND LS1 COMMON PROBLEMS
What common problems have you guys faced with in your fbody? I had a 2000 z28. I enconterd: My Cat, ac compressor, and my window motor. I just got a 98 z28(still less than 75k) and already i belive the fuel pump is going out and also the switches for the ac system? Let me know what problems you guys have faced with these cars.
Old Jun 20, 2005 | 11:35 AM
Hennytime's Avatar
window motors went at 34k miles, only problem, that and the wanting for more power
Old Jun 20, 2005 | 11:38 AM
elite22xl's Avatar
did you guys really expect the GM window motors to last more then 35k miles? hah. one of mine went at 42
Old Jun 20, 2005 | 11:39 AM
Durien's Avatar
the problem with mine is keepin my foot off the gas
Old Jun 20, 2005 | 11:47 AM
jlashley2001ss's Avatar
stock rotors tend to warp (POS). other than that its a NEED...... A NEED FOR SPEED!!
Old Jun 20, 2005 | 12:04 PM
CompTA's Avatar
Window motors, headlight motors, parking lights, b-pillar paint
Old Jun 20, 2005 | 12:12 PM
bowtieman81's Avatar
window motors and the stock rotors warping. I also have a t-top rattle that I am tracking down and a rear hatch squeek that is proving difficult to track.
Old Jun 20, 2005 | 12:18 PM
shouldaboughttheZ's Avatar
Window motor @ 63k
Driver side front rotor @ 65k
Old Jun 20, 2005 | 01:13 PM
LawmanSS's Avatar
Window motors...my driver's side window has been slow since the day I took delivery of the car when it was brandy-new...other than that, the problems I have had have been self-induced by modding the crap out of the car...
Old Jun 20, 2005 | 01:18 PM
hpjunky98's Avatar
what would be a good replacment for the stock window motor?
raul602's Avatar
oil pump
Old Jun 20, 2005 | 01:24 PM
spy2520's Avatar
Passenger window motor and AC compressor both at around 72k miles. It wouldnt hve been that bad if both things didnt happen at the same time.
Old Jun 20, 2005 | 01:28 PM
JBIRD02's Avatar
window motor, water pump, countless bulbs on the front passenger turn signal, headlight, tail light.
havent fixed the window yet, but water pump aside, everything else was a cheap easy fix
Old Jun 20, 2005 | 01:30 PM
RyRy's Avatar
Only problem is warped rotors at 20K now theres 28K and thats the only problem
Old Jun 20, 2005 | 01:46 PM
NviouSS's Avatar
my drivers side window didn't even last 30k miles.
Old Jun 20, 2005 | 01:52 PM
SOMFormula's Avatar
18K on the 2002. Replaced 6 speed tranny (warranty). Noise from POS 10bolt rearend. Warped rotors (replaced under warranty with brutestop rotors). Interior door panels cracking right near the window. Just little **** that is frustrating, but when I put the vertical peddal on the right down to the floor, I could give a rats *** about the shotty build quality.
Old Jun 20, 2005 | 02:09 PM
spy2520's Avatar
my window isnt really a problem if i open the door while putting it up, if the door is closed, it'll stop anywhere on the way up.
Old Jun 20, 2005 | 02:19 PM
GreekGator's Avatar
alternator @30k
window motors at 35k
Old Jun 20, 2005 | 02:24 PM
blkZ28spt's Avatar
Same as usual. Window motors and rotors. I replaced my driver's side motor right after getting the car four years ago, the passenger motor went out last sept and I just now bought a replacement to put in this week. Not only that, but I guess I'll get practice cause the driver's motor is acting up again.
I also need to learn how to swap rotors/pads in my parking lot cause not only are my stock rotors warped but have some easily visible (one you can feel) cracks in them.
Brembo blanks or autozone rotors plus hawk HPS pads, here I come.
Old Jun 20, 2005 | 04:53 PM
Chas1's Avatar
Window motor is slow, just replaced rt side headlight motor. The left front turn signal assy had to be replaced(wireing burnt up, WTF?). 66k.
