Oil weights and grades
Dave
The time period it takes to use up these additives varies depending on the way you drive. Short trips that don't let your oil heat up and drive off the moisture uses these additives up quickly. Longer drives don't.
Less immediately urgent but still important is the fact that as you drive your car there are places within your engine that produce localized hot spots. Those hot spots in particular, and normal operating temperatures in general, drive off from your oil the lighter and more volatile portions of your oil. As this happens your oil gets thicker. All oils do this but the synthetics do it less than conventional oils.
Add the two together and you get a limited useful life. Your mileage may vary.
So how's visability with it? I've been looking at getting a 4" cowl hood, actually...For comparison, I go to the track at least twice a month during the season (probably around 12-15 trips to the track in a year, around 60-70 or so 1/4 mile passes) and I change my oil & filter once before race season, and once after... so every 6 months. And my oil comes out looking great even after 6 months of fairly harsh use. In fact I could probably go longer, and just change the filter.
And I'm just using the lowest cost oil Amsoil sells, which is their XL formula. If I used their Severe Service 0w30 or 20w50, I would go with 1 year intervals, change the filter at the 6 month mark.
Point is, synthetic oils are getting better and better, really making the 3 month/3000 mile interval obsolete.
It's your dime, however you would get the same levels of engine wear if you went 6 months/6000 miles. I've got the oil analysis results which prove this.
