Oil weights and grades
Lately i've been getting slightly lower oil pressure than i had before. It is always close to 40 -plus or minus for throttle- right after an oil change, but 1500 or so mile into it it rests at around 20 at idle, probably not a problem.
But thats not what this is about. What i want to know is:
Which oil do you use and why?
What is the difference in all the types of oils people use on this site and is it merely based on outside temp and mods?
DO A SEARCH. Oil questions come up a lot, esp in the internal engine forum it seems.
The best are full synthetics, obviously. Amsoil, Mobil 1, german/belgium castrol and royal purple. I went with Mobile 1 0w40 and mobile 1 filter recently. (had been using standard valvoline and fram filter. DON'T USE FRAM!) Good old 5w30 should do just fine for average use. As I said, do a search, you'd be amazed how much you can find about oil.
I'd go with Amsoil or Mobil 1. You can get the Mobil 1 a lot of places, such as autozone. It's usually $4.50-$5.50 a quart, depending. For filters Wix, K&N, Mobil 1, etc. BUT NOT FRAM
If you have any questions about Amsoil, I'll be glad to answer any questions I can. I'm an independent dealer, and I do have special pricing for fellow LS1TECH members. Just can't post them, so you'd have to PM me.
I have an oil change coming up and will definitely be looking into your amsoil prices tranzor_z28.
First thing is protection of the engine. This is basically covered by the weight of the oil which is repersented by the 40. The higher the number the thicker, and more lubricating the oil is. This is especially good in racing applications, and high temperature applications.
The second is how well the oil flows. This is repersented by the 0w. THE LOWER THE NUMBER THE HIGHER THE VISCOSITY AND FLOW. 0w flows awesome. This means it takes less time for the oil to be circulated thoughout the engine as wells as it takes less time for the oil to get up into the valve train on cold starts. As well a high viscosity is great for cold climates. The bottle states the the oil will still pour at -56. Thats impressive.
All together its a great oil, and I saw a 10-15 psi increase on my oil pressure guage, as well as the engine seems to start and run smoother and quieter.
On a side note the results of my oil analysis, this oil was run for 6000mi, the flash point was off the chart. over 450 degrees. I was impressed with that. Lets see penzoil 10w-30 last that long!
Nathan
Nathan
Excellent write-up. The W next to the first number is how the oil acts when it's cold (0 degrees F). The next number is how it acts at 210 degrees F. I run the same oil in my car and picked up some pressure. One more thing about running a synthetic. Synthetic doesn't thin down as much at higher temps, therefore the oil companies don't have to put as much Viscosity Index (VI) improvers in the oil to make it a wider multi-viscosity range (0W-40 for example). However, with a dino oil, they have to put a lot of VI improvers in it to make it a multi-viscosity oil. Then when the oil gets hot for a long period of time, the VI improver additive has a tendency to start evaporating. I used to run a 20W-50 dino oil in one of my cars a while ago and I always changed my oil in the middle of the summer here in Arizona and always picked up oil pressure with fresh oil.
By the way, thick things (honey) have a higher viscosity, thin things (water) have a lower viscosity. Oils are measured at a representative operating temperature for purposes of comparison (40°C or 100 °C).
For the first number in 5w-30, the smaller number represents the weight of the oil when cold. In this case the oil has the viscosity and flow like a 5 weight oil when cold. This is important at startup and during cold temperatures to get oil distributed quickly.
The larger number represents how the oil will act at temperature. In this case the oil has the viscosity and flow like a 30 weight oil when hot. This is important during the normal operation of the engine, keeping a strong film of oil on moving parts.
Folks who explore the operating limits of their engines on the high side might want to use a higher weight oil to keep that strong film of oil on moving parts. However, too thick of oil will compromise gas mileage, and too thin of oil will allow more metal to metal contact.
Auto companies will indicate use of a thinner oil (0w-20) to meet fuel mileage requirements and to work with the closer tolerances of modern engines.
Modern oils provide outstanding protection for engines across the spectrum of weights. On dyno day you may want to use 0w-20 to help produce a couple more horsepower, and on racetrack day you may want to use something in a 40w to provide protection at extended high temps and engine abuse.
But for normal driving, 5w-30 or 10w-30 in a sythetic is extremely sufficient.
My .02. Thanks for reading.
For comparison, I go to the track at least twice a month during the season (probably around 12-15 trips to the track in a year, around 60-70 or so 1/4 mile passes) and I change my oil & filter once before race season, and once after... so every 6 months. And my oil comes out looking great even after 6 months of fairly harsh use. In fact I could probably go longer, and just change the filter.
And I'm just using the lowest cost oil Amsoil sells, which is their XL formula. If I used their Severe Service 0w30 or 20w50, I would go with 1 year intervals, change the filter at the 6 month mark.
Point is, synthetic oils are getting better and better, really making the 3 month/3000 mile interval obsolete.
has anyone noticed the pic in my sig, just added it recently and am very proud!!! lol
So how's visability with it? I've been looking at getting a 4" cowl hood, actually...
