Sponsored by: CARiD
Having problems with my coolant
Old Jun 21, 2005 | 01:00 AM
yekta's Avatar
Default Having problems with my coolant
I don't know where to open a topic but I think I should change my radiator system. When temp. is @ 210*, if I stop the car coolant starts to overflow! I changed my thermostat with 160* Hypertech and nothing changed! I mix water and cool-dex exactly 50-50. Everything looks fine and I donno what to do. Maybe I should put a button for direct manuel access to fans
Old Jun 21, 2005 | 12:27 PM
natronathon's Avatar
maybe it is just overfilled. Take a look at the resivour levels... are they at the proper line for "running" and "cool"
Old Jun 21, 2005 | 12:30 PM
shouldaboughttheZ's Avatar
You switched to a 160* thermostat. Did you reprogram the fans to come on earlier?
Did you bleed the air out of the system?
Old Jun 21, 2005 | 12:32 PM
yekta's Avatar
Even its overfilled or not it doesn't really matter, last night I ran out of coolant and Car went crazy man!
I didn't program it yet stephen, didn't bleed it either. How can I bled the air
Old Jun 21, 2005 | 12:37 PM
http://www.installuniversity.com/ins...ostat_swap.htm
start with step 13. I did this exact same procedure and have had no problems. I would also look into getting the fans reprogrammed.
Old Jun 21, 2005 | 10:49 PM
nvrstsfd23's Avatar
i have the same problem after my cam swap but we didn't bleed it from that hose. and i can let the car run for as long as I want or drive the **** out of it and nothing but as soon as i turn it off it will start to hiss and push fluid into the overflow tank. Once the car cools if I take the cap off of the radiator it gurgles and lets some air out. Does this mean that there is still air in the system because it seems to be getting less and less each time or is it possible that I have too much coolant in the car.
Old Jun 22, 2005 | 07:53 AM
Mr Incredible's Avatar
Here's something I found a bit ago. It may or may not be relevant to your problem...
Engine Runs Hot, Overheats, Loss of Coolant (Polish Filler Neck/Replace Radiator Cap) #00-06-02-001
Engine Running Hot, Overheating and/or Loss of Coolant (Polish Radiator Filler Neck and Replace Radiator Cap)
1999-2000 Passenger Cars and Trucks
with Composite Radiator End Tank
Condition
Some customers may comment on one or more of the following conditions:
Engine running hot
Engine overheating, and/or
Loss of coolant/low coolant message
Cause
The radiator filler neck may have an imperfection in the sealing surface.
Correction
Important
DO NOT REPLACE THE RADIATOR.
Using a piece of 400 grit wet/dry sandpaper backed with a flat piece of wood, polish the filler neck sealing surface using a circular motion.
Replace the radiator pressure cap with a cap of the same part number as shown in the GM Service Parts Catalog.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
J3020 Cap, Radiator Filler - Replace 0.2 hr
Old Jun 22, 2005 | 12:23 PM
yekta's Avatar
MAN this is exactly what s happenning to me, and it happened after changing my muffler
wow incredible, and stephen nice informations! Thanx in advance
Old Jun 22, 2005 | 11:06 PM
nvrstsfd23's Avatar
that doesnt sound like my problem
Old Jun 24, 2005 | 05:09 AM
steven99WS6's Avatar
From: Tomball TX right outside (north) of Houston TX
I saw that you said you mixed water with your dexcool, I did this after I got my car not knowing any better and heard later that if you mix water and dexcool it gels and makes a grease like substance, and it did in my car I had to flush it out and re fill with nothing but dexcool because it over heated, this might have something to do with your problem.
Old Jun 24, 2005 | 10:47 AM
yekta's Avatar
But my problem is not over heating, my problem is coolant loss
Thank you tho
Old Jun 24, 2005 | 12:32 PM
BlkZ28LS6's Avatar
So you have only anti-freeze in your radiator? Or is it the dexcool pre-mixed with water? You need a 50/50 mixture of coolant and water in there.
