Window motor?
Is my motor going bad. How much does it cost to get it fixed or is this something I can do myself.
I used the same link as above (http://www.metalreviewcentre.com/Window.htm).
Long version: At the point where they tell you to reach into the door through the speaker's hole to unclip the wires from the motor....yeah I could NOT find the stupid clip without being able to see it. I had two mirrors on telescoping rods and a flashlight. After trying to unlcip it for awhile I decided that this was stupid and just went ahead and drilled the rviets out. Sure enough, it was 1,000 times easier to unclip once the motor was no longer attatched. Took five seconds at that point, as I could hold the motor in front of the speaker's hole and see everything.
Short version: Go ahead and drill out the rivets before attempting to unclip the wiring harness from the motor.
This was asked just a week ago and its on page 4 of this section.
Here is the thread:
https://ls1tech.com/forums/general-maintenance-repairs/338473-power-window-works-5-secs-then-doesn-t-2-mins.html
Its even a sticky over in the Stereo & Electronics section:
https://ls1tech.com/forums/showpost....1&postcount=18
I have flashbacks of my past Firebird, and horrors of the windows/motors...
CONSPIRACY THEORY:
.I have to thank you guys for the replies and links provided without them I wouldn't have been able to do this job. Another plus I got out of this was I fixed a rattle that was coming from the inside of my door. It was the lock linkage had come out of the rubber grommet that holds it in place.
