Sponsored by: CARiD
Removing Driver Air bag
Old Jul 7, 2005 | 02:44 PM
CONVERTED's Avatar
Default Removing Driver Air bag
95 t/a I've replaced my whole interior with ebony (black) out of an 01 formula. but the dash and steering wheel are still graphite...
I bought a new steering wheel(no air bag) and remotes but fear the danger of replacing my steering wheel because of the airbag.. how are is it to remove??? is it as dangerous as many shops say it is... When my horn wouldnt' work and my radio buttons didn't work i called around to see who could replace the coil and everyone freaked out because it had an airbag so I had to take it in the butt from the dealer.... So how hard is removing the airbag/ steering wheel?
Old Jul 7, 2005 | 02:56 PM
ROCNDAV's Avatar
Its not as bad as everyone makes it sound. I had to do this on a Geo Metro once and I am doing the same as you to my Camaro (94->01). I'm at work and dont have my 94 GM service manual with me right now, but I will look it up when I get home. I just moved, so I might not be able to find the right box tonight. Anyway, from what I remember it was as simple as removing the fuse then unplugging the yellow wire. I'll try and look up that stuff for you.
David
Old Jul 7, 2005 | 03:06 PM
Charging TA's Avatar
Search the forms, basically disconnect the battery... remove the airbag and disconnect the wire... remove the steering wheel... Theres other threads on this, one not too long ago.
Ive had a Camaro airbag sitting under my bed for years...
Old Jul 7, 2005 | 03:10 PM
ROCNDAV's Avatar
What side and from what year?
Old Jul 7, 2005 | 04:18 PM
z28boysteve's Avatar
just get the apropriate size torx bit, and remove the 4 screws to the airbag assy., then gently pull and disconnect the wires, there will also be this ribbon looking thing on a spool, its been so long I cant remember what its for, but be carefull not to **** it up taking it out, then use a steering whel or ballancer puller to remove the wheel.
Old Jul 7, 2005 | 04:24 PM
CONVERTED's Avatar
Thank you all.... i'll get it done here soon....
if anyone knows where I can get an ebony leftside bag let me know...
Old Jul 7, 2005 | 04:34 PM
Cant recall, its driver side though... I remember trying once to sell it on ebay but no one purchased it. Ill take it out later tonight and see if it says what year it is.
