Sponsored by: CARiD
radiator fluid? red, green?
Old Jul 16, 2005 | 04:53 PM
jmilz28's Avatar
To answer your question, you can use either - just do not mix them. Red (dexcool) lasts longer than green but tends to get acidic and sludgy. Use green and flush the whole system each year or use red and do every 2. The f-bodies cooling system isn't sealed well enough to really benefit much from the extended life of dexcool. The main culprit is the crappy reservoir/overflow tank. Best for maximum cooling is along what nineball said, though I would add some water wetter. Most racers use distilled water and water wetter but that's no good for longevity in a street-driven car. 50/50 mix (red or green) and you can't go wrong. Flushing the system often will preserve your gaskets, though LS series engines aren't known to have many problems with them.
Old Jul 16, 2005 | 05:57 PM
miacamaro305's Avatar
well i have a 89 tbi 5.0 camaro w/ a single fan setup
