Sponsored by: CARiD
radiator fluid? red, green?
Old Jul 11, 2005 | 08:46 PM
MiaSSmaro98's Avatar
Default radiator fluid? red, green?
alright i did the t-body bybass freebie mod and some red antifreeze came out i fill up wat was missing with water,but i will like to replace the fluid.but my question is which one do i use red or green?and if red were do i by it at?
Old Jul 11, 2005 | 08:59 PM
Nine Ball's Avatar
LS1Tech Co-Founder
You need "Dexcool". It is pink colored and you can buy some at any autoparts store.
If you live in a hot climate, you can just use water to top it off. Water actually has a higher thermal conductivity rate compared to antifreeze, so your engine always runs cooler on water.
I typically use 25% antifreeze and 75% water. (Texas summertime)
Old Jul 11, 2005 | 09:08 PM
miacamaro305's Avatar
so u cant use green?
Old Jul 11, 2005 | 10:12 PM
jmm98LS1's Avatar
Nope....just use the red.
Old Jul 12, 2005 | 09:07 AM
spy2520's Avatar
i always thought you just couldnt mix the two, if red is completely gone you can change to green otherwise the two will gum up and F **** up.
Old Jul 12, 2005 | 11:22 AM
Charging TA's Avatar
I always thought that standard coolant would have a higher boiling point than water
Old Jul 12, 2005 | 10:07 PM
Phoenixta99's Avatar
It does. I dont know what this guy thinks. Water has boiling point of 273degrees (F) whereas the average boiling point of cooolant (red or green) is 370 degrees(F). I feel sorry for that Texas LS1.
Oh, and by the way, mixing green and ared coolant is asking for trouble. Some coolant says that they can mix with any color, but if you have a $6,000 drivetrain, dont you think you should protect it with what is reccomended? Answer is GM Dexcool.
(50/50 mix, not 25/75)
-Phoenixta99
Old Jul 13, 2005 | 02:53 AM
loyolacub68's Avatar
Thats why he didnt say boiling point, thermal conductivity is the measure of a materials ability to conduct heat. He is simply saying that water conducts heat better than antifreeze which will make your engine run cooler, boiling point has nothing to do with it, whether or not its true I have no idea but it seems to make sense due to waters very high potential thermal conductivity. I would bet antifreezes potential is lower than water.
Old Jul 13, 2005 | 02:58 AM
In fact I have an old truck thats probably been running about 20% antifreeze 80% water with no problems for years now. Been hoping it would kick the can last few years so I never do any maint on it, its been going strong for a while in SoCal.
Old Jul 13, 2005 | 11:04 AM
AnotherScreenName's Avatar
There have been a few (some lengthy) threads about this and it always seems to end up at a draw. If one completely removes the dex cool sucess can be had with the green. Usually the people using green have had contaminated dexcool causing sludge to form in the cooling system and block passages and get fed up and switch. Whatever one you choose, don't wait until 100,000 miles to change it.
Old Jul 13, 2005 | 12:13 PM
I agree with your theory about the conduction of heat (Hell, heres the definition)
Thermal conductivity
Conductivity \Con`duc*tiv"i*ty\ (k[o^]n`d[u^]k*t[i^]v"[i^]*t[y^]), n. The quality or power of conducting, or of receiving and transmitting, as heat, electricity, etc.; as, the conductivity of a nerve.
Thermal conductivity (Physics), the quantity of heat that passes in unit time through unit area of a plate whose thickness is unity, when its opposite faces differ in temperature by one degree.
Source: Webster's Revised Unabridged Dictionary, © 1996, 1998 MICRA, Inc.
but when you slap water onto a block at around 240 degrees, there is a chance for flash boil and condensation: hence, evaporation if you remove the cap or de-pressurize the system. Regardles of ability to conduct or not, water is water, and all im saying is that water alone cannot withstand the forces of heat that cooland/antifreeze can. Granted, coolant/antifreeze is only at it's best with the addition of water, but that by no means makes it more "heat worthy" as Texas was making it out to seem. I live in So Cal as well, but I've never ehard of the 20/80 or 25/75. Hey, if it works, thats great- i might have to check it out!
Old Jul 13, 2005 | 12:15 PM
Oh: and MiaSSmaro, if you DO put green in, make sure you reverse flush th engine and not just the radiator: a little of mixing makes the best radiators go bad.
Old Jul 13, 2005 | 01:03 PM
Phoenix, I totally agree with you, the potential for flash boiling is exactly the reason why you should have the proper level of antifreeze in the car, you know and stated this. I'm just saying it can work, the 20/80 in my truck isnt on purpose, it has a leak that comes and goes for whatever reason. It seems whenever I pour antifreeze in (the only one that costs money), the damn thing starts to leak, so I just said screw it and left it alone. Like I said above, I have no idea if its true or just as good having less antifreeze in there, I was just trying to point out that what he was trying to say didnt have anything to due with the difference in boiling points.
Old Jul 13, 2005 | 01:09 PM
I see. Oh- another thing... be careful with mixing colors if you dont know what was in there before 100%. Even if the coolant/water mix seems orange/red/pink; there still can be a problem. When the most common radiator/gasket stop leaks are added, they tint the green a different color- hence, the orange. I watched as a lesson was learned on my friends Twin Turbo VR4 ( I know, rice talk). Anyway- now he's not sure if it's a cracked block, or just the head gasket. Either way, he's got some work ahead of him.
-Phoenixta99
Old Jul 13, 2005 | 06:27 PM
good advice and commets.mines is a light pink color so i hope they never put green in there.how many gallons does are systems take?4 gallongs?2 anti and 2 water?
Old Jul 14, 2005 | 08:50 AM
jkichline's Avatar
I have a '95 T/A and use 50/50 green. The LT1 runs hot (~230°F) in stop and go traffic but cools to a steady ~180°F above 50mph. This tells me that the radiator seems to be doing the job but the fans are not sufficient for stop and go. With the air conditioning on in stop and go it runs cooler at around 210°F. I know the fans are on with the air compressor working making the water temp a little cooler. But without the A/C on, the fans kick in at ~ 200°C. Why the cooler temp with the A/C on? Its been like this for years and I haven't figured it out. I have flushed the coolant a few times, there's a new water pump, thermostat, and radiator cap.
Old Jul 14, 2005 | 10:32 AM
yeah my 89 camaro runs hot to in stop in go traffic the ls1 does great though.im just gonna get the red stuff
Old Jul 14, 2005 | 01:58 PM
Yeah... those 305 and the 350 L98 cant idle for the ****... my bros had three and my friend had one before he bought his LT1 (and I did mine). The LT1 ran way cooler than my new LS1 when driving, but I didnt have too much control in stop and go. Nonetheless, stop and go, driving, etc. I've never seen mine go a hair past 240. And just to let everyone know, a good full radiator flush is reccomended every year of 12,000 miles.
Old Jul 14, 2005 | 02:30 PM
777's Avatar
777
A manual fan switch, or adjusted fan activation temps will solve the rising temps when not moving.
Old Jul 16, 2005 | 02:34 PM
2000 TAWS6's Avatar
BTW, water boils at 212F or 100C, in case any one cares.
