Sponsored by: CARiD
Car doesnt start
Old Jul 27, 2005 | 03:30 AM
Justin01SS's Avatar
Default Car doesnt start
Ok weird situation. Car doesnt want to start. Turns over, all electronics come on, but it just doesnt fire. it is getting fuel, but not fireing. Heres the kicker, it doesnt do this all the time. Its totally random. Sometimes it fires up like a champ, no problems what so ever. Others, it takes between one and several times to get it to turn over. Ideas on how to troubleshoot?
Justin
Old Jul 27, 2005 | 05:08 AM
Seagraves#85's Avatar
Justin
Ignition relay! Swap the ignition and the starter relay (since they are side by side) and see if that will make it start every time. This is a common problem with the F-bodies.
Good luck
Old Jul 27, 2005 | 08:29 AM
mike3605's Avatar
Were you doing anything with the battery recently? If so, make sure your negative battery cable is secured to the battery - I had the same problem when I changed my alternator - the bolt wasn't all the way tight, and all my electonics worked, but it wouldn't turn over. I tightened it, and viola - turned right over.
Old Jul 27, 2005 | 11:22 AM
The car wouldnt turn over if you had a loose ground connection. But still a good place to start checking.
Old Jul 27, 2005 | 02:15 PM
Justin01SS's Avatar
what am i looking at as far as price to replace ignition and starter relay?
Old Jul 27, 2005 | 03:46 PM
Not too much $, I would say no more than $10 but if your car is turning over but not starting I would start by swapping the relays to see if that works. What I mean by swapping is to pull both relays out and put the starter relay in the ignition relay and vice versa, the relays are identical and work exactly the same. This will narrow the problem down, the starter relay doesnt "relay" as much power as the ignition relay so you might be able to get away with just swapping them for now until you get a new one.
Old Jul 27, 2005 | 08:34 PM
Justin01SS's Avatar
Well i switched the starter and ignition relays and the car has fired up 10+ times with no problems. Ill wait a day or two before i do a happy dance but looking good. Thanks seagraves!
