Sponsored by: CARiD
Window motor repair possible?
Old Aug 2, 2005 | 08:13 PM
Krab's Avatar
Question Window motor repair possible?
I've got a factory window motor sitting in the garage that I never threw away (was on it's way out) and my g/f's window motor is going out too. I was wondering if there's anyway to repair the motor? I figure I have an extra window motor to mess around with, so why not give it a try. I know I've heard about replacing the solenoid because it gets too hot therefore causing the motor to work in short bursts after it cools down. Does anyone know for sure? I've done a couple of searches on the subject, but came out empty handed.
Old Aug 5, 2005 | 07:07 AM
Krab's Avatar
Anyone ever attempted this?
Old Aug 5, 2005 | 02:33 PM
CAMAROWITHBASS's Avatar
Default ..
a guy on camarov6.com repaired his
apperently if you open it up somehow there is a small resistor that burns out on them.
He replaces the 1 cent resistor and bam it worked again, for a few days that is. untill the resistor burned out again...
maybe you can replace the resistor with a higher resitance resistor.
Old Aug 6, 2005 | 09:18 PM
Krab's Avatar
I might just give this a try. I gotta figure out a way to open the darn thing now... Thanks for the ino!
Old Aug 7, 2005 | 12:48 PM
PrototypE's Avatar
I'd recommend against trying to repair it, Reason being, it's such a pain to replace 'em, that, should it not last, You'll be back in there, fightin' it again.
For this reason, I'd just get a brand new one and be done with it.
Old Aug 7, 2005 | 01:10 PM
well you dont open the whole thing, you somehow dissasemble the part where it connects, go to camarov6.com under the general forum search for it, i bet the post will come up. it gives details on how the guy did it.
Old Aug 7, 2005 | 10:47 PM
VIP1's Avatar
Copy & Paste Moderator
Its really easy to replace the power window motor on a 4th Gen F-body. I did mine for the first time in under an hour. If I had to do it again, I could do it in 30min.
Check out these how-to's:
https://ls1tech.com/forums/showpost....1&postcount=18
