replacing Turn Signal bulb on 98 Camaro?
Hi
Need to change the driver side turn signal bulb. No access panel from underneath on a 98. Hard to see and reach in from the top.
There appears to be 2 different bulbs. One socket mounts from the top and has a clip that is on a right angle and the other socket is much smaller near the corner of the lense assembly and goes straight in. Can anyone tell me which socket is the turn signal and also how it releases. Both sockets seem to be stuck in there prettty tight.
Thanks JA
Thanks JA
It's in the middle kinda facing the outside of the car I guess you could say, they just twist in, lefty loosy, righty tighty... It's a pain in the *** though
Originally Posted by JGA
Hi
Thanks JA
Thanks JA
good luck!
Hi
I like removing the headlight idea. I believe it is the one with the right angle connector about in the middle of the lense body. Counter clockwise to loosen I think, but I have not tried it.
Thanks JA.
Thanks JA.
