Sponsored by: CARiD
Brownish Coolant
Old Aug 9, 2005 | 01:04 AM
CASHss99's Avatar
Default Brownish Coolant
99 SS
my coolant is a brownish liquid and its not clumpy at all just brown,,,, is it time to change?
when they say flush what is that?
and how would i know to start filling it?
Basically how do you do everything?? thanks guys
Old Aug 9, 2005 | 09:10 AM
Muffracing's Avatar
You need a coolant flush. Drain the radiator. leave the radiator pet **** open. Take off one of your heater hoses. Hook up the garden hose to the heater hose. let it run until it comes out clear. Hook to hose to the other side and back flush through the engine. Let the radiator drain out. Blow air through the heater hose to clear out the water. Find the capacity of the cooling system (in owners manual). Close petcock on radiator and hook up heater hose. Fill half the system with strait antifreeze. top off the radiator with water.
I would put green antifreeze back in. It is cheaper and won't turn brown and sh*tty like dexcool.
Old Aug 9, 2005 | 09:13 AM
777's Avatar
777
What's the deal between green antifreeze and dexcool. I have heard SO MANY different things and not one straight answer that is a fact. Can or can you not put green coolant in the engine.
Old Aug 9, 2005 | 09:45 AM
Muffracing's Avatar
The dex cool is supposed to be better for alloy engines, but when it is exposed to air it turns to ****. Turns brown, smells really bad, and gets kind of chunky. Manufactures have been using aluminum intakes with green antifreeze for ever and haven’t had problems. I don’t see why they all stopped using green antifreeze. Yes you can run green, just flush the system first. If you want to change back, just flush out the green and put in dexcool, but don't mix them.
I believe the main difference is the green has silicates and the dex cool is silicate free.
Old Aug 9, 2005 | 10:16 AM
prelude00782's Avatar
don't wait because right now that brown coolant, if it is very old, is destroying your radiator and other parts. I'd change the thermostat too but just make sure you flush it, like above have said.
Old Aug 9, 2005 | 10:54 AM
Mr Incredible's Avatar
Dexcool is not a bad coolant if minimum maintenace is done. Dexcool is silicate-free and will not coat the inside of the cooling system. That coating will reduce your system's efficiency. It is also better for water pumps and seals.
Dexcool's main natural enemies are air and non-distilled water. Additives not approved for Dexcool are not good. If you don't check your fluid level and it gets low it will suck air in and out of the system, thus creating an undesireable condition.
While advertised for 5yr/100,000 miles, in the real world that may be optimistic. If you are like everybody else here you will check your system regularly and replace at 2 or three years.
Green coolant is the answer for those that don't understand or like Dexcool. But there's nothing wrong with Dexcool that checking your coolant level regularly, topping off with distilled water, and changing it regularly won't keep away. That's just basic maintenance!
Flushing your coolant system will remove all the expired coolant and back flushing will remove more scale and deposits than simple flushing will remove. Kind of like petting your dog backwards...
Old Aug 9, 2005 | 03:48 PM
RFERG43's Avatar
ALL antifreeze made today is formulated for use with aluminum engines and radiators. They wouldn't be selling much antifreeze otherwise. I use Prestone. Says right on the label "good for all engines".
Old Aug 9, 2005 | 07:19 PM
CASHss99's Avatar
thanks guys, does anyone have any pics of this routine mabey, cause i'd probably pull teh wrong hose and do some stupid things i dunnno lol???
Old Aug 9, 2005 | 09:33 PM
89lx-ls1's Avatar
definetly put green back in. It will take just alittle while to flush but it good main. to do once a year i think
Old Aug 10, 2005 | 03:28 AM
HFLDtA's Avatar
Dont forget to bleed it!
Old Aug 10, 2005 | 06:17 AM
demonspeed's Avatar
It's not mine! woo hoo!
Yup, that's the stuff you want. It can mix with both Dexcool and the green stuff.
Old Aug 12, 2005 | 12:10 AM
CASHss99's Avatar
dont forget to bleed it? what do you mean...
so run a hose for awile , while the drain is open? then fill up green and start teh kar then fill more if needed?
Old Aug 16, 2005 | 11:17 AM
jkichline's Avatar
Question
I got a 95 that came with green and I haven't changed. A friend of mine uses Dexcool. He mixed spicket water with his and the coolant is turning brown and clumpy. Above, a guy says that non-distilled water is dexcool's enemy. Is this really what happens when you don't use distilled water? My friend thought that the clumpy stuff is gasket material that has broken off and settled itself up to the top of the resevior tank. Looks like somebody in it. Anybody have any thoughts on this?
Old Aug 17, 2005 | 10:55 PM
ws six six six's Avatar
what he means is, fill the radiator up, then keep the cap off, start the car, and watch as the coolant bubbles down while all the air bubbles work thier way out. Once you stop seeing bubbles come to the surface and the coolant starts to rise up to the cap, just make sure that the radiator is full, then cap it off, drive it around for a little while. After that bring it home, let it cool down then remove the cap and top it off one last time. Then your good to go
