Sponsored by: CARiD
Creaking noise
Old Aug 9, 2005 | 03:40 PM
2000 TAWS6's Avatar
Question Creaking sound, help needed!!
What is strange is that it does not happen all the time. If get in the car and take a 20 minute ride. it will not happen.
If a take a 20 mile ride through traffic, over some bad roads, then I get a creaking sound. It sounds suspension related, but then it also sounds like a transmission member noise.
It also seems to only happen when going slowly.
Is there any notorious culprits to look for? Could it be control arm bushings, do these do this (my first LS1 f-body)?
It as a 00' WS-6 M6 with 73K miles.
Thanks up front for the support.
Old Aug 9, 2005 | 07:22 PM
2000 TAWS6's Avatar
Question Creaking noise, help needed!!!!
Old Aug 9, 2005 | 08:56 PM
jaberwaki's Avatar
after 60k-80k miles it a good idea to replace all your suspetion bushings
Old Aug 9, 2005 | 09:11 PM
Reject's Avatar
yeah and remember to put some good grease in tehre or else it'll start squeking all over again!!
Old Aug 9, 2005 | 09:14 PM
black00TA's Avatar
i agree with the above statements. also, if u have any aftermarket suspension parts i would start there.
Old Aug 9, 2005 | 09:35 PM
89lx-ls1's Avatar
Just spray some wd-40 on the control arm bushing and you should hear a diff. if it is them. If not i would chek out the spring pads to see if they are wore through.
Old Aug 10, 2005 | 01:36 AM
black00TA's Avatar
better make it marine grade white lithium grease
Old Aug 10, 2005 | 09:02 AM
Reject's Avatar
WD-40 wont work, the squek will just come right back after a few miles...i've tried taht 4 times now almost wasting 2 full cans of it on the bushings, you need to get inside were the rubber meets the metal with some good GREASE.
Old Aug 11, 2005 | 04:59 PM
joe_kool315's Avatar
I think he ment to use the wd-40 as a way to "find" the problem ... not solve it. Once you locate the culprit then grease to your hearts content or change it out for new as reccomended above
Old Aug 11, 2005 | 08:47 PM
2000 TAWS6's Avatar
Is there a "sticky" that details this procedure?
Can motor mounts make a noise similar to what I described?
