Sponsored by: CARiD
Brake lights stuck on
Old Aug 9, 2005 | 08:53 PM
Terroristkiller's Avatar
Unhappy Brake lights stuck on
Help I T-boned a car today and got minor damage to the front end. Well tonight I noticed that my brake lights are stuck on. The only way I could figure out how to turn them off was to unplug the battery.
Old Aug 10, 2005 | 02:00 AM
DONAIMIAN's Avatar
Look under the dash above the brake pedal and you should see a white (i think) spring loaded switch. When you press the brake pedal, the switch extends and the lights come on. When you release the pedal, it pushes the switch back in and the lights go off. You should see some threads around it to adjust it.
