Sponsored by: CARiD
Clicking noise
Old Aug 10, 2005 | 07:05 PM
GuesDog's Avatar
Default Clicking noise
I was making a low speed left turn and heard a wierd clicking sound coming from the rear, and when i engage the clutch it clunks a bit also, only at certain times but not violent. what is it?
Old Aug 11, 2005 | 01:46 AM
ACW's Avatar
ACW
Sounds like this might be your issue
"A ping, snap or click that is heard as the transmission is placed in gear or the suspension is loaded."
Possibilities:
- The pinion yoke is loose. Tighten the bolts and the pinion nut to the specified torque.
- One or more of the universal joints are worn or damaged. Replace the universal joint.
Old Aug 11, 2005 | 09:26 PM
DarkOneX's Avatar
I have the same clicking type noise only when turning left as well. Sounds like it's coming from my rear passenger side, possibly at the wheel...
Old Aug 23, 2005 | 08:18 PM
DarkOneX's Avatar
Had my car looked at today by the dealer shop. They found that my right rear wheel has some "play" in it and they are ripping it apart to fix it. Not sure offhand exactly what it is but they said it'll be covered under warranty! w00t
Old Aug 23, 2005 | 08:21 PM
2kt/a's Avatar
that, my friend, sounds like an outer axle bearing. good thing you bought the extended warranty!
Old Aug 25, 2005 | 08:58 PM
DarkOneX's Avatar
Got my car back today, it's fixed! They had to rebuild the whole rearend they said, it cost them over $1800 but only cost me $50!
Old Oct 26, 2007 | 09:31 AM
ssvegas's Avatar
ever find out what was causing this?
Old Oct 26, 2007 | 09:56 AM
Greggy's Avatar
I'm pretty sure it is the rear axle bearings. 100k on my car and I will be replacing both axles, axle bearings, axle seals, and c-clips. I'm pretty sure the differential, ring, pinion and center section bearing probably are pretty worn as well, but I'm not touching them.
The axles usually get ate up when the bearings go. I'm using Superior Axles for alot less than Mosers or GM. When I get them in I will let you know if the clicking and scraping noises from the rear wheels is gone.
Old Oct 26, 2007 | 10:06 AM
ssvegas's Avatar
cool.
but i had my rear checked and they said the bearings and everything were fine. maybe they didn't look good enough...?
this clicking has been driving me crazy!!
Old Oct 26, 2007 | 10:11 AM
Greggy's Avatar
It's tough to diagnose the problem as I only get the noises when the car is rolling on the ground. The c-cip axles move in and out a bit by design. My wheels only have a tad of up and down movement, but you can hear more banging back there over a series of small bumps and the clicking noises come and go. They get louder the harder I drive the car.
Old Oct 26, 2007 | 10:31 AM
ssvegas's Avatar
my clicking gets louder as i slow down and or turn left in neutral.
i feel like im driving a POS!!
maybe i should grow a mullet.
Old Oct 26, 2007 | 12:27 PM
patSS/00's Avatar
Mine also has a clicking noise on very low speed turns. I did a search and found out that this is supposed to be normal for a Torsen diff.
Old Oct 26, 2007 | 12:43 PM
ssvegas's Avatar
hmmmmm
someone should be fired.
how do i know if i have a torsen??
Old Oct 26, 2007 | 02:05 PM
Greggy's Avatar
the torsen sound is like a bucket of marbles being shaken and comes from under the rear seat. Axle bearing sound is very uniform, like one click or scrape for every wheel rotation 3ft, and come from the out the left or right window towards the rear.
Old Oct 26, 2007 | 03:47 PM
patSS/00's Avatar
Yeah mine is definitely not a uniform click but more like the marbles in a can.
