Sponsored by: CARiD
Oil Pressure Problems
Old Aug 11, 2005 | 05:00 PM
SSJIMMY's Avatar
Default Oil Pressure Problems
My oil pressure gauge shakes when ever I am sitting a red light or anywhere else. just shakes enough to notice maybe 5-10 PSI. I have changed the oil and also changed th spark plugs and My RPMs are at 500 when Idle. Just trying to figure out what it is the car shakes when sitting and feels like it may stall sometimes but never has. the car did shut off on me goning down the road at about 50 and then it started back up which freaked me out so I pulled over and checked everything and then drove home. I used NGK TR55 plugs, Fram filter, and Valvoline oil. Thanks for the help and I hope someone knows whats going on.
Old Aug 11, 2005 | 10:12 PM
ACW's Avatar
ACW
Here's some possible causes of oil pressure problems
"If the engine oil pressure is below specifications, inspect the engine for one or more of the following:
Oil pump worn or dirty
Oil pump-to-engine block bolts loose
Oil pump screen loose, plugged, or damaged
Oil pump screen O-ring seal missing or damaged
Malfunctioning oil pump pressure regulator valve
Excessive bearing clearance
Cracked, porous, or restricted oil galleries
Oil gallery plugs missing or incorrectly installed
Broken valve lifters"
Old Aug 12, 2005 | 05:42 PM
SSJIMMY's Avatar
thanks for the info does anyone else have any more input on this also it seems to happen more when the car is warm.
